Question about Garden
My john deere mower clutch is stuck frozen and it will not start...what happened
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I remove the PTO clutch from a John Deere
Locate and disconnect the power supply cord from the clutch. Remove the bolt, washer and retainer from the center of the clutch, It should now slide off the end of the crankshaft provided you have previously removed anything such as body parts or braces that would be in the way. In some instances penetrating oil must be used to help free it up. When you reassemble it, it is a good idea to use a little bit of anti-seize on the engine shaft in case you have to remove it in the future.
Posted on Oct 30, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
Wiring diagram for LX172 John Deere
Type into google john deere riding mower wiring diagram for pto switch clutch circuit then click images
May 12, 2016 | John Deere Garden
My john Deere 100 series .... Gear stuck in reverse.... And will not start because it is stuck in reverse!
sit on the mower and push the clutch in
start moving the mower by rocking it forward and backward while trying to put it in neutral,don't worry about your neighbors thinking their is something wrong with you while you are doing this.
Oct 10, 2014 | John Deere Garden
Trouble shoot a John Deere lx 188 clutch?
Sounds like new belt is jammed or something is out of place. Turn by hand and find out where the problem is. You can tell where the belt is stuck or jammed. Pull the key before you mess with stuff underneath the unit. I installed my belt the wrong way on my unit and ruined a new belt and it would not shift.. The shifter rod could have been dislocated when you installed the belt also.
Jul 27, 2014 | John Deere Garden
John deere l130 has frozen clutch pedal
Check petal and linkage for a stick or etc. in there.
Apr 22, 2014 | John Deere Garden
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
I have a John Deere STX46 and the back wheels are locked.
Check to see if the brake is stuck. check on the ****** on the right side for a small disk and a lever with a rod through it with a spring on the end. Try moving this lever by hand and see if it frees the wheels. If its is stuck spray some lube on the assembly like PB blaster or liquid wrench.
Oct 14, 2012 | John Deere Pto Clutch For Stx38 And Stx46...
I have a John Deere L-130 and the electric PTO appears to be engaged even when the switch is turned off and the wiring to the PTO is disconnected. I can start the engine (with the wiring disconnected) and...
Good diagnostic work, uncleparroth! By removing power to the PTO, you've proven that the PTO clutch has stuck/frozen mechanically. If you are mechanically inclined, you can remove the PTO clutch assembly and disassemble it. You could luck out, find something as simple as a broken spring and save a lot of money. Nothing to lose but your time. On the other hand it might not be repairable and you'll have to 'spring' (sorry for the pun) for a new PTO clutch which will cost about $200. Good luck!
Aug 08, 2010 | John Deere Garden
Fuse problem on John Deere 318 lawnmower
Does the mower have an electric clutch the clutch could be going bad if it has one unplug the clutch and see what happens
Oct 19, 2017 | John Deere Garden
Sep 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
