How do i adjust contrast on dell inspiron 1520 laptop
byteguy
  • 2229 Answers
SOURCE: Power chord won't charge laptop
If you need to wiggle the cord in order for it to charge, then you have a problem.
If you have to wiggle it at the computer, you probably have either a bad plug on the adapter or the power connector on the motherboard is going bad. This situation will not cure itself. It will only get worse.
Check the voltage at the end of the power adapter cord (the plug where it goes into the computer). If it's constant even when you wiggle the plug, you're gonna be looking for a new motherboard soon. I have actually replaced the power adapter on motherboards, but it's tricky--you have to be really good with a soldering iron!
Posted on Mar 22, 2009
  • 5 Answers
SOURCE: How to Unlock Dell inspiron 1520 Laptop Password
I is my understanding that you can contact Dell with the service tag, and express code and get the master password to clear forgotten passwords.
Posted on Jun 08, 2009
  • 4 Answers
SOURCE: dell inspiron 1520 error code 2000-0146
I had the same problem and came across this solution that worked for me as well:
Re: windows Vista will not start 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Posted on Aug 21, 2009
  • 98 Answers
SOURCE: how to replace Dell inspiron 1520 inverter
Have to call Dell technical support.
Posted on Oct 07, 2009
SOURCE: my dell inspiron 1520 has dark screen
I just "fixed" a 1520 that had a similar problem. The screen would go dark at odd times and would always go dark if the power adapter was UNplugged. After upgrading the bios, chipset and video drivers with no improvement I started fooling with the power settings.I found that setting screen brightness to anything less than 100% when on battery power caused a totally dark screen on battery power. Definitely some kind of bug and running with 100% brightness on battery will reduce battery life but I got it working. I think the bug was apparent after some recent updates. It could be the O/S or drivers. YMMV
Posted on Dec 02, 2009
Dell inspiron 1520 won't turn on. battery indicator light at right sidr of laptop blinking blue
I would like you to try this step
1.Remove the battery and try to turn on again.
Update us with more information of this.
thanks
Feb 22, 2015 | Dell Inspiron 1520...
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
I have dell 1520 how to remov bios password plz help me
vDell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1520-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Dec 07, 2009 | Computers & Internet
I have a Dell Inspiron 1520 laptop. Fan has gone
that is absolutely right i work for the same and we charge $49 If you bought the sys. after sept. 2004. and you are out of warranty.***let me know what is the blue screen all about.and stop erros code with 0x000000** this blue screen will help us to understand the issue. and i can help you to resolve your issue.
Nov 06, 2009 | Dell Inspiron 1520 Motherboard
Hi how do i change the contrast on my dell inspiron 6400 laptop???
If you have ATI Graphics, then in the CATALYST Control panel, Color Tab is a the CONTRAST adjustment.
If you Intel GMA Graphics, then there is no Contrast Adjustment
Sep 23, 2009 | Dell Inspiron 6400 Notebook
May 09, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
