Air conditioner not working
When i turn on air conditioner hissing sound coming from coils i can hear that it trying to turn on but its not also fan is working fine.
  • 79 Answers
That singing sound you hear from the coils mean the system has lost it's refrigerant charge, due to a leak in the refrigerant lines. Most of the time repairing the system is more expensive than buying a new window unit. Make sure you get a bid before repairing it.
Posted on Jun 24, 2009
Air was not cooling but indoor fan was working. Checked outdoor unit, fan not working and hearing like a vibrating/humming sound.
If the condenser coil is very dirty it may have tripped a manual reset high pressure switch try and locate it on the condenser , Also check breaker feeding unit. If it comes back on turn off at the thermostat and wash condenser coil with a garden hose .
Oct 12, 2015 | Heating & Cooling
AC unit wont work, inside coils are hissing but outside unit not turning on.
If thisnis a central air conditioner and there is hissing at the indoor coil then the compressor is running, it is possible that both fans are not running. The indoor motor may not run if the control board is bad, capacitor is bad or the motor itself is bad. The outdoor fan may have a bad capacitor or the motor itself is bad
Jul 23, 2012 | Heating & Cooling
My Amana AAC101SRA doesn't cool like it used to. We have cleaned the filter, but that doesn't seem to help. Should we call a repairman or think about getting another unit?
Is the outdoor coil blocked? Is the outdoor coil clean? Is the compressor running when you start unit. When you turn unit off after running it can you hear a hissing sound from within?
Aug 02, 2011 | Amana High Efficiency AAC101SRA Air...
Unit cools then sound like hissing noise then stops cooling sound like relief
Hi, this hissing you hear is the head pressure getting very high in the system due to the out door coil is very dirty. It shuts the compressor down until it cools off again, then repeats its self again. Take a water hose and wash down the outdoor coil being careful not to flatten the aluminum fins. This will solve your problem! Good luck,
Shastalaker7
A/C, Contractor
Jun 22, 2011 | Friedrich QuietMaster KM24L30 Wall/Window...
Air conditioner isn't blowing cold! Fan works okay but air isn't cool. Can hear hissing sound that sounds like normal compressor function. Do I need a coolant recharge?
You will need the condenser coils repaired before you can charge it. These come from the factory sealed and they should not ever need a charge unless you have a leak. The hissing sound is more likely air in the system being pumped by the comressor and it is coming out a hole in the coils.
May 29, 2011 | Frigidaire FAH126N2T Thru-Wall/Window Air...
Compressor fan mtr hot, hear it try to energize for approx 2 seconds then stops aproximately 1minute later cycle repeats, removed coil voltage and manually acuated coil did not hear anything trying to...
The motor bearings have siezed up and the motor needs to be replaced...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 22, 2010 | Goodman CPLE24-1 Air Conditioner
Rudd Heat pump shuts down. Compressor is on and goes out on
Is your condensor coil clean?Needs air to breath.
Feb 12, 2010 | Ruud UBHC Air Conditioner
Cooling is ok, but in heating mode thermostat cuts too early, even though the temperature set from RC is too high and not reached. At thermostat cutting I hear the pressure drop hissing sound. Then after a...
Will you check to see if the coils can breath? (Like check the air filter --the evaporator coil and the condenser coil. Sounds like its starving ffor air!
Dec 07, 2009 | Daewoo DSA-122L Air Conditioner
No cold air and motor works intermittingly.
the fan motor is stuck take front cover off reach inside and turn fan by hand then try agin let me know
May 25, 2009 | Maytag M6X06F2A Air Conditioner
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
