Question about KitchenAid 32 in. KECC508 Electric Cooktop
How do I bypass the automatic shut off for my KitchenAid electric cooktop kecc568mbl00 so I can cook stocks longer?
4 Suggested Answers
  • 60 Answers
SOURCE: What electric voltage plug do I use for KitchenAid 32" cooktop
I would use the 220volt 60amp available at any hardware store. Just make sure you check the wall outlet you are going to use. The Dryer and Range are not the same.
Posted on Nov 07, 2008
  • 1214 Answers
SOURCE: ELEMENT WONT SHUT OFF
Sounds like that specific element has shorted to ground inside it's sheath. You'll probably find the element does not get as hot as it normally would.
A fuse will not blow, or breaker not throw, because of the point in the element that the element has grounded.
Elements are available from a number of resources.
A way to test if the element is shorted to ground:
Tools needed -
Ohmeter
1)Disconnect power from the appliance
2) Remove the element (Sometimes they are plugged in, sometimes the wires screw onto the ends of the element.
3) Set the Ohmeter to Rx1000 or more.
4) Measure the resistance between the outside metal sheath, and either of the two power connection points on either end of the element. Under any condition, you should not get a reading. If you do, the element is bad, and you need to get a new one. They are not repairable.
5) Re-install in the reverse removed.
6) Check all connections are clean and all is re-assembled as you originally found it.
7) Turn on power and check if element comes on.
It is unlikely the problem is with the control, but it is a possibility. Give me more info about the cook-top (make, model) so I can investigate further.
Posted on Jan 14, 2009
heatman101
  • 43501 Answers
SOURCE: electric ignitors will not shut off gas cooktop range
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Jul 25, 2010
Do you have in stock this product:KitchenAid 36 in. KECC568 Electric Cooktop
Nope this is fixya not a retail site
Sorry you have posted on the wrong site
Thanks for the points
May 14, 2015 | Cooktops
How do I remove the blower motor on a Kitchenaid cook top model number kecd866rww01
I think that you have to lift the whole cooktop out and the blower assembly is attached to the bottom.
Installation manual and user manual are here for viewing or download.
KITCHENAID Counter Unit Electric Parts Model KECD866RWW01
Sep 30, 2014 | Cooktops
Electric ignitors will not shut off gas cooktop range
this video shows how to replace everything on your cooktop, at will help you troubleshoot!
Jul 22, 2010 | KitchenAid 31 in. KGCC505 Gas Cooktop
The circuit breaker for out kitchenaid glass
Water probably did get into the switch(es). The best bet for a fast fix is to pull the knobs off and use an air can (like for blowing dust out electronics) to blow down into the holes. This will dry out any water in there and should allow you to use it again. To be extra sure, blow out the switches and leave the knobs off over night. In the morning the knobs can be replaced and the cook top should be good to use. Hope this helps!
Dec 11, 2009 | KitchenAid 30 in. Architect KECC507KSS...
I was cooking popcorn on my glass cooktop and the pan appears to have scratched to surface.
You may have melted the bottom of the pan you were using into the glass. Copper bottom and alum pans sholdnot be used at high temps on a glass top. (never use porclin or glass pots)High temps can etch(mark or discolor) the glass.
Oct 30, 2009 | KitchenAid 30 in. KECC506R Electric...
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Auto electric lighter for the gas stove no longer works
gud day,the problem is ur igniter ligther is totally damage & nid to replace, if u want to use ur cooktop use matches or ligther every time open ur gas cooktop,tnx gerbee
Nov 17, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Cooktop shut off and lock itself up
36" electric wolf brand cooktop. Goes off completely after just few seconds sometimes 30 sec. sometimes minute..Repair man looked at it-thinks either something electrical or some sensor messed up.He took apart look at electric ribbon nothing looked over puts back together..turns on and it goes completely blank again..no error codes..any suggestions
Feb 22, 2008 | Cooktops
KitchenAid 32 in. KECC508 Electric Cooktop Logo
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
