Question about Mtd 25B-520D200 CA Gas Lawn Edger
Where can I get an edger blade - Mtd 25B-520D200 CA Gas Lawn Edger
    Top Expert:
  • Mtd Master
  • 51,187 Answers
Any home improvement store that sells lawn equipment
Posted on Feb 01, 2016
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Change an edger blade
Start here to find User's Manual. Sometimes the nut/bolt holding the blade on is a Left Hand thread and requires CW turning to loosen and remove. Not sure on this model.
Aug 12, 2012 | Poulan Pp1000e 7-inch Pro Lawn Edger...
I bought a homelite curb runner and need to replace the blade. The problem is I cannot find the blades anywhere. Any ideas?
I found that your electric edger blade is rounded on the ends. I did not find a part number for it. I also found a site that has about 30 or more Homelite edger blades listed, but again, with half of them without pictures, I can't give you the edger blade part number. But, if you have removed the blade and can measure all the dimensions of the blade, then you can match it up with one from this site.They have more blades than other sites I checked. It should not be too hard as each blade listed has the critical dimensions listed with it. I wish you good luck.
http://www.mowtownusa.com/42.html?m5:search[keyword]=Edger%20Blade;search[keywordSearchType]=and;search[matchWholeWords]=1;search[keywordFields]=string0:text2:text0:code;search[active]=yes;search[fuzzy_sku]=1
Jun 19, 2011 | Garden
Blade is turning wrong way
The blade drive belt on your MTD edger makes a half twist in its pattern. When the belt was installed, it was twisted the wrong direction. Remove the belt from the blade pulley and reinstall with it twisted the other direction. Before you start the edger again, visually inspect the belt and make sure it is not touching anything other than the pulleys.
Dec 21, 2010 | Yard Machines Red Edger
We need a new blade for our craftsman edger
Go to www.searspartsdirect.com. Put your model number in of your edger.
It will show you a parts list , which will include your blade.
Hope that helps.
Good day.
Oct 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Aug 03, 2009 | Garden
Trouble un-screwing edger blade bolt
It may have left handed threads and needs to be turned clockwise to unscrew. As for sharpening an edger blade...it won't cut any differently. That short blade, traveling that fast and rubbing against concrete is going to do it's job, sharpened or not.
Jun 20, 2009 | Garden
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
Are you supposed to sharpern the blades on the edger occasionally
Hello:
No. Edger Blades are Not Sharpened.
Respectfully
John
May 09, 2009 | Black & Decker Le750 Lawn Edger
How to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Apr 09, 2009 | Garden
Mtd 25B-520D200 CA Gas Lawn Edger Logo
93 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
