Question about Spinmaster Air Hogs Jet Set - Red Acro
Airhog spin master model 44398 won't fly. Propellers spin but all it will do is bite the dust. Does anyone know what could be wrong?
2 Suggested Answers
SOURCE: does anyone know where to buy a new main prop
Look for places that distribute "Air Hog" Products in your area. They should be able to help you.
Posted on Dec 28, 2010
I did check all the propellers and they were ok I would like to contact the seller but I don't have any address to do so I am hopeing it is still under warenty
What is the issue with the quadcopter?
All propellers spin but it flips over when trying to fly?
This would be clockwise and/or counter clockwise propellers on the wrong motor(s). For copters with an even number of propellers, each propeller turns the opposite direction from the ones on either side of it. The reason for this is so the combined engine torque is in equilibrium. Unbalancing this equilibrium is what allows the craft to turn left or right without a rudder or tail rotor.
Regardless of spin direction all propellers must blow air downwards.
Aug 11, 2014 | HUBSAN X4 H107c 2.4g 4ch Rc Quadcopter...
Hi my syma quadcopter x1 is stuck in the eversion how can i fix this ?? Thanks
Jun 22, 2014 | Syma rc x1 aerobatic bee quadcopter 2.4ghz...
I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
Why won't my HP laptop stay on? I have a 2nd HP laptop and both models happen to have the same lithium ion battery so I swapped the battery of the working HP to the non working one to see if it wa
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 15, 2012 | HP Computers & Internet
My rc helicopter won't fly just spins like crazy
You have posted this in the wrong product category. Please re-post the question in the correct category.
Apr 27, 2012 | Cars & Trucks
The little flight stabelizer thingy above the propeller on my helix 360 is not working properly. i can hold it in my fingers and while the propellers are spinning i can see the stabelizer is tipping...
Check for damage to any of the linkage. You may also remove the tiny pin on the stabilizer and take it off. use a nail file or dremel tool to round the edges... giving it a more aerodynamic shape, and you a chance to make it balanced. After you do this, wrap each tip with a small piece of clear tape. This mod is good for any of the "square" AirHog balance bars.... it gives you more response and faster movement in all directions. ~VLAD~
Dec 30, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Havoc wont fly
try spining the blades.
Jan 01, 2009 | Air Hogs Havoc Heli Helicopters
My Havoc Heli got wet
Most likely you short circuited something and now it can't be fixed. I would send it back to the company to be replaced.
Spinmaster Air Hogs Jet Set - Red Acro Logo
Top Spinmaster Toys Experts
ray gallant
Terry
Terry
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
