Question about Craftsman Garden
I need to remove cover for starter rope on model 917.388740 what tool do i use to remove hex screws
  • Craftsman Master
  • 2,760 Answers
This mower is supost to have a briggs engine on it , it has a plastic top cover that envelops the entire top of engine , most times these covers are held down with TORX screws , a five sided pointed screw these usually are available in sets
Posted on Jul 09, 2015
4 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: starter rope broke
Unless you know how or have the patience of Jobe save yourself a lot of grief and take it in to a lawnmower repair guy.
Posted on Mar 24, 2009
  • 109 Answers
SOURCE: replacing starter rope on Briggs engine 133702, type 017002
On some models of mowers...depending on the maker of the mower, the rewind housing is bolted onto the engine cover with 3 screws. On the rest they are riveted and the only way to get to the crank rope is from underneath the housing...but, they do make refits for the mowers where you can replace the rivets with bolts
Posted on Apr 19, 2009
  • 579 Answers
SOURCE: Troy-bilt pull rope torx screw: Is there a trick
There is no trick, you would just use a torx screw driver. If your spring isn't broken don't do this. If your rope is broken you can fix easily. Replace old rope with new rope of equal size, place rope into spring wheel and turn counter clock wise holding the spring wheel. place other end of rope thru hole in shroud, remember to hold tight you have a lot of tension there. Pull rope thru enough to tie a knot, replace your pull handle , untie the knot and you should be fine. GOOD LUCK.
Posted on Aug 13, 2011
How do you get drive shaft apart to get to starter rope?
Hi Donna:
Most of the pull start assemblies are attached so that their centre is directly over the centre of the driveshaft. There will be several bolts that connect the assemby to the engine, and when they are removed, the pull start assembly can be lifted off.
If you turn it over and look at the underside, the cover for the spring and rope will be attached, possibly with pop rivets, or it may be held in place by a centre bolt.
Patience and caution will be your friends as you determine how to dis-mantle it.
If the spring is broken, see if you can get some tips from the service people where you buy the replacement.
May 09, 2015 | Garden
How do I replace recoil spring on generator
Depending the manufacture of the engine the actual replacement varies. You basically need to first remove recoil starter cover assembly. In the center in most recoil rope pulleys will be screw(bolt) that need to be removed. Pay close attention the assembly order or the parts; take picture if necessary. Once you things a part and old spring is removed. Be careful even broken springs can go flying and cause injuries. Carefully put the new spring in the correct direction. Re-assemble the rope pulley unit. To put tension on the spring you wind the pulley in the same direction as it would if you was pulling the rope out. Wind until it stops then unwind up to one turn depending where the rope enters the pulley and install the starter rope. After the starter rope is installed slow let the pulley take up rope slack. Then you re-install the starter cover assembly on the engine.
Note on some engine other components needs removing just to the starter cover off. I know of some Briggs engine that this is true as the carburetors has to come off first.
Jan 12, 2015 | Electrical Supplies
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    How do you get the starter rope to rewind after pulling to start my 25 cc poulin pro trimmer? How do you access the recoil spring?
    The starter rope normally rewinds automatically when the recoil unit is functioning properly. If the pull rope has stayed out, disassembly will be required. Here are instructions for that problem. The recoil spring can break and is replaceable, but the nylon hub in the starter recoil unit is usually the problem or the rope has broken and jammed inside.
    Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Here are more details for servicing the starter/recoil unit....With the starter/recoil unit OFF the machine, with no rope in it, and no tension on it.....grasp the little nylon hub and turn it (clockwise is I recall) round and round 6-7 times until you feel the recoil spring get nice and tight...DO NOT LET GO OF IT!...hold it in place and then JAM the starter/recoil unit in place (still tight) inside it's housing by either clamping it with a tool like vise grips or by sticking a screwdriver thru it and thru the vents in the cover. If you have ANOTHER person to help you...one of you hold it in place....and make sure it is lined up to where you can NOW insert the new lenth of pull rope. Always use new rope....Feed the end thru the hole in the recoil unit and tie it off, by wrapping it around itself outside the nylon hub and then screw the little self-tapping set screw back in holding the rope down. OK...then feed the opposite end into the hole in the front engine cover and attatch the T pull handle....Now mind you, you are still jammming or holding the recoil in place against the spring!...Now, unclamp it or unjam it and slowly let the recoil pull the NEW rope you just installed back onto the pulley. Make sure it is fastened well on top of the pulley around the nylon hub and also fastened well onto the T pull handle. That is it. Then reconnect your wires, put your throttle cable back thru the engine cover and reinstall the Torx screws in the cover...and you are doneervicing the recoil unitl
    Jun 04, 2011 | Poulan Garden
    Rope on Craftsman Convertible weedeater wont rewind.
    Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, ou will have to lock up the engine. Remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or something so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place. Reassemble and you are done. Disassembly requires Torx head drivers ranging from T-15 to T-25. Here are more details involving the starter/recoil assembly.
    May 27, 2011 | Craftsman Convertible 14" Gas Line Trimmer
    Starter rope replacement instructions for a model tb10cs troy bilt trimmer
    Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed
    May 07, 2011 | Troy Garden
    Pull starter rope will not retract
    Disassembly and inspection/repair will be required. Here are the steps to take.
    Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers or a good flat blade screwdriver for some models.
    Nov 15, 2010 | Yard Machines Garden
    Need to replace starter cord on Tecumseh LV195EA engine for walk behind lawn mower
    This is an easy one. You need a #2 phillips screwdriver, a 1/4" nutdriver or socket, a 5/16" nutdriver or socket, 84" of #4.5 braided nylon rope, scissors and a lighter or flame of some kind.
    1. With the #2 phillips screwdriver, remove the 2 screws that hold the green plastic cover to the top of the engine. This is just a decorative cover.
    2. With the 5/16 nutdriver, remove the 3 screws in the top of the fuel tank. Lift the tank straight up about 3/4" and then just lay it back on the rear of the mower deck.
    3. The round black object on top of the motor is the starter houseing. You will find it being held on with 2 screws from the side. The 1/4 nutdriver should fit these. Remove them, and note the position of each screw and the position of the starter top. It might help to put some colored tape on the starter top and on the upper engine shroud to make sure you put it back in the same position. The starter top will come off by lifting it straight up.
    4. Remove what is left of the old rope.
    5. carefully wind the inner pulley (the same direction the rope will pull it) until it is tight. Then let it rotate back a little until the rope hole in the pulley lines up with the rope hole in the starter top. Use your screwdriver to hold these in place by putting it through the pulley and starter top vent holes.
    6. Measure your rope out to 84inches and then cut it. Take the lighter and melt the ends of the rope to keep them from ravelling. When you melt the ends, take a paper towel or a rag and wipe the ends to form a point. This will make reinstall easier.
    7. Push the rope throught the eyelet of the starter top and through the hole in the pulley and tie a figure 8 knot on the inside of the pulley. Tie the starter handle on the other end. but do not tighten this knot, you may have to untie it to lace it back through to where it goes.
    8.. Hold tension on the rope and remove the screwdriver. The rope should retract into the starter top.
    9.Reinstall everything in reverse order.
    Nov 01, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
    The pull cord on my 25cc craftsman gas trimmer broke and went back inside the trimmer. I looked up several online site for assistance to replace the broken cord. At the point, I've removed the back...
    You can't remove the motor shaft from the front. That is NOT what you are trying to do anyway. Here are all the steps you need to take to get to the pull start assembly which is located inside the front cover. Torx head screws are used exclusively on these but you may be able to grab some of the fasteners with a flat-blade screwdriver. I'm not sure if you have removed the clutch drum (has the screw that backs out but doesn't come out) so here you go.
    Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers.
    Oct 15, 2010 | Craftsman 25cc Gas Line Trimmer
    Starter rope broke. how do i get the cover on the
    Once u split case open you have to remove the engine from the frame to get to the starter. Its somtimes a bear to get back together due to warpage in the case halves. Hope this helps
    Nov 16, 2009 | Homelite 'Yard Broom' Leaf Blower
    Garden Logo
    95 people viewed this question
    Top Craftsman Garden Experts
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Dennis Key
    Dennis Key
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
