Question about ADI Corporation MicroScan A708 17 in. Flat Panel LCD Monitor
Desktop too large for monitor
We got out computer fixed recently (new power supply because of lightning)...now the desktop is too big for the monitor. It's making my husband crazy because he has to scroll back and forth and he can't play Spider! Poor baby. Help!!! I've tried everything I know to do. I called the computer guy thinking he had re-set some setting...but he had no clue. Why would this happen? I've gone into settings under properties...tried it all....HELP!!!! Please???
  • Sandy Skogen-McClure Jun 24, 2009
    It's an ADI A505. Model Number is L-152. 15'' TFT LCD monitor. My OS is XP. My resolution is set at it's highest option.
    How do I "unadjust" the bios if that is the problem? I don't know what that means...sorry. Rookie. :)
    President:
  • 1,996 Answers
This has to do with the resolution settings on your display, or someone has changed the default dpi, or the bios has been adjusted.
What OS are you using? xp? vista?
What make & model # of computer?
Right click the desktop, choose properties> then settings>make sure the screen resolution is set correctly, then choose advanced and make sure the dpi is set to normal. Reboot.
If that doesn't work, check for another graphics tab in the advanced settings for your display, like Intel graphics or something, and check the screen resolution set there and adjust it if necessary.
Otherwise, check the osd for your monitor and see if it's set to factory specs.
But I'm guessing the techs that did the work on your power supply had a different sized monitor hooked up and made an adjustment they forget to reset.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 23, 2009
  • efs_perpends
    efs_perpends Jun 24, 2009
    This has to be a windows adjustable setting. It won't be in bios. If you go into the control panel>display>settings>advanced, go to the monitor setting and make sure there's a check mark in hide modes that this monitor cannot display, then turn the monitor off from its power button, then restart it. See if there's any improvement.
    Try adjusting the refresh rate and see if it has an effect. The optimum for your monitor is 1024 x 768/60Hz . Here's the support page online for that monitor, and here's a link to a troubleshooter. But try changing the resolution, then rebooting windows, then adjust it again if necessary and see if there's any effect. I think this has got to be a windows software issue, or possibly a corrupt driver.
    Go to windows update and check for any graphics/video updates that might be available for your system.
    Then use the device manager to check the status of your display adapter. Rt click My computer>manage>device manager, choose display adapter and rt. click it, choose properties, then scan for hardware changes. See if this will correct the situation. if not, use the troubleshooter here to reinstall the driver for your monitor. Select troubleshoot, then I can't set resolution above 640...
    then follow the steps to reinstall the driver for the monitor. (Make sure you have the original drivers cd in case of problems, and set a system restore point prior to doing this, just in case you have to revert back.)
    Otherwise, you might try running chkdsk according to instructions here and here, to see if your system has been corrupted.
  • 43 Answers
It looks like your display driver is not installed or corrupted
check your display driver by right clicking my computer click the hardware tab ,then click the device manager
    Scholar:
  • 41 Answers
Your monitor resolution is just too small. You need to increase your resolution.
For Vista:
Open Control Panel.
Click on Personalization
Click on Display Settings
Move the bar where it says "resolution" to it's maximum allowable size.
For XP:
Go to desktop, right click an empty area, and click on the properties menu item.
Scroll through the tabs. Look for an Appearance or Display tab. There is a bar labeled Resolution, and you should be able to drag it to increase or decrease your resolution.
I can not turn it on. How can I fix a no power problem?
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing and replacing the PC power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect ,boot up a computer hard drive
WARNING Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Power surges are damaging spikes of voltage in an electrical systems, caused by lightning strikes, changes or problems with the electrical grid, or large appliances.
Power surges damage or destroy computer hardware by overheating circuit boards and other components.
Surge protectors and other devices are used to protect computers and other electrical devices from power surges.
If damage occurs to a computer from a power surge, a process of trial and error is used to replace the damaged components.
Replace the surge protector or power strip.
If neither was attached to the computer, it is highly recommended that one be used.
Follow the user's manual to open the computer.
The computer manual may have shipped with the computer in book or CD form or may be found online.
Examine the system and make note of any visibly damaged components.
Damaged components may show visible burn damage or no damage at all.
Follow the user manual to remove the power supply.
You will need to unplug the power connections to each device in the computer as well as the system board.
Removal is generally achieved by removing the holding screws and lifting the power supply out of the system.
Follow the user manual to install the new power supply.
Plug the power cables into the computer components and the system board.
Close the case.
Do not re-insert the screws.
Plug the power cable into the computer and attempt to power the computer on.
Replace the power cables to the monitor and computer.
Examine the monitor.
If the monitor does not power on, it will need to be replaced.
Determine if both the monitor and computer power on.
If the monitor powers on but the computer does not replace the system board.
If both power on but there is no video signal, replace the video card.
Boot the system into Windows.
Go to the "Control Panel" and double-click on the "System" icon.
Click on the "Hardware" tab. Double-click the network card, sound card, and other peripherals that are listed in the hardware tab.
If you replaced the system board, ensure that the device drivers are in place for the peripherals. Replace any peripheral that is still non-functional.
Computer Repair Tutorial Help and Tips
http://www.thepcmanwebsite.com/computer_repair.shtml
Jul 01, 2013 | Lenovo IdeaCentre K320 3019 PC Desktop
Power surge due to lightning strike today. Comp...
Unplug it and then blow a hairdryer at the power supply for 3 minutes. Leave the lid on, just blow the hairdryer at it from the outside. Craziest trick I ever saw.
After that, turn off hibernation. And eventually, replace your power supply.
May 20, 2010 | HP Compaq Presario SR1300NX (PP195AA) PC...
A7V 400MX ASUS Mother Board: Problem
i had same thing - was power supply,,,,replaced and all fixed, now boots properly everytime
Mar 15, 2009 | ASUS A7V400-MX Motherboard
Compaq Presario Wont Boot
Hi, my name is ArmyMason, hate to tell you this, but it sounds as if you have a bad Processor. Did you recently experience a bad storm with lightning? Was their a lot of dust on the fan? Lightning could have struck the computer and killed the processor or excessive overheating of the processor could have also been the case. If it was a lightning strike I would contact the insurance agency and have them replace your computer. Reason I think its the processor is because you don't recieve any post and the fan spins for a second and then shuts off.
Feb 23, 2009 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Toshiba Qosmio QG10-133 powers on , but screen is compltely dead. I did't get any thing even on external monitor. Plz give me any advice. Thanx a lot
check the power supply on the rear..is the fan blowing..if not, the computer will overheat and not start
have you added memory that isnt compatable, if so , remove it and try to restart
have you updated anything recently? is the large main battery completely in it's slot? new USB device?
check a few of these things and post here again , i will help you all i can..
Oct 22, 2008 | Computers & Internet
Possible hardware conflicts when installing a new monitor.
No, i was running windows xp professional edition. I finally got so fed up I went and bought a new computer. i would still like to have any suggestions about how to fix it since i have three of the darn things and would like to find a use other than paper weight for them.
Apr 27, 2008 | Dell OptiPlex GX270 PC Desktop
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Vertical lines on LCD monitor
You have capacitor problem in power supply, if many lines then replace the bigest cap and find anymore that needs replacing. Its an AC filter problem.
Sep 14, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
ADI Corporation MicroScan A708 17 in. Flat Panel LCD Monitor Logo
1,054 people viewed this question
Top ADI Corporation Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an ADI Corporation Computer and Internet Expert? Answer questions, earn points and help others
