Question about Canon ZR60 Mini DV Digital Camcorder
Tape goes in but comes right back out.
Everytime I put a tape in to record or just watch, my camera starts beeping and tells me to remove the tape. It does it automatically; however, whether the lid is closed or not.
    Problem Solver:
  • 14 Answers
If you can get a head cleaner in the machine during one of those tries, run it for 10 seconds and try a tape. If you know how to take the door off and how to clean a machine with head cleaner, I think this will solve your problem. Always use the same brand of tape. Each company has their own lubricant and mixing tapes will gumm up the insides and cause tapes eject problems.
Videoteacher
Posted on Jan 08, 2008
When i put a tape in it ejects it..then a tape with a slash appears on the screen
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Beeping c:31:23
I bought a new handycam that has no tape it recirds in Mini-DVD disks or a memory card. I just got fed up with tapes. Thanks.
Jan 23, 2009 | Video Cameras
Cannot play or record st comes up with eject tape
Camera has Mechanical/ Electornic problem (Reel signal missing) and needs qualified technician to fix it.
Jun 03, 2008 | Sony Handycam DCR-TRV250E Digital...
Wont Record
Usually when a tape starts to play automatically this means that the tab on the back of tape has been removed to stop others recording over it check the tab little black tab in a recess on back edge of tape if this is missing you can put a bit of sellotape over the whole to blank it off this will tell the video tape is ok to record on.
However if the tab is still in place the try putting a small bit of tape over it also to raise the clearence slightly then put back in video and try to record if this still dont work then the mechanism that detects the tab has failed these can be replace but usuall parts are hard to come by now as they no longer make vcrs any more but let me know ok i can assist you further just check tabs in place even try raising it with a bit of card stuck over tab with tape this might make the tab switch work if it has wonr down abit let me know ok.
As you look form back of tape the tab is bottom left hand corner check its flush with the tape if not use sellotape to repair let me know the outcome ok
Feb 15, 2008 | Televison & Video
C 31:20 is my special message
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 11, 2008 | Sony Handycam CCD-TRV608 Camcorder
Canon camocorder thick gray lines on ever recording
Supreemwun,
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Jan 13, 2008 | Canon ZR100 Mini DV Digital Camcorder
Camera won't record a certain tape
either the tape is sticky or is hard to take the reel. that's why it's beeping.
Aug 07, 2007 | Canon ZR45MC Mini DV Digital Camcorder
It keeps making a beeping noise and wont let me record or do anything!
Try taking off the battery and reinserting it to see if it resets mech,If this doesnt work you wil have to bring to service.Dont go at it yourself as you could cause serious problems,
May 23, 2007 | Sony Handycam CCD-TRV68 Camcorder
Will not accept any tape
i bought this camara from someone with the same problem for 5 bucks at a yard sale. an easy fix. 1. blow the dust out 2. charge the battery. 3. put the tape in and when it gos down into the case close the door and turn it on, run tape on ff then rr then turn camara to record. if it says to eject tape at any time, eject it and do it again. it worked for me.
Jan 11, 2007 | Canon ZR80 Mini DV Digital Camcorder
Has error
Dec 24, 2006 | Sony Handycam CCD-TRV308 Camcorder
Canon ZR60 Mini DV Digital Camcorder Logo
159 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
