Question about Balboa Instruments Pool & Spa
Hi, i have an image renew 639 hydrotub with balboa system 2000 le m7. I set the temp to 100 now the temp is 105 and the pump is not shuting off. please help
    Top Expert:
  • Balboa Instr... Master
  • 5,045 Answers
Possible bad temp sensor or relay
Posted on Aug 30, 2017
2 Suggested Answers
dayminner
  • 159 Answers
SOURCE: I get F2 and SL code on my SUV M7 balboa spa pack
Hi there, it took awhile. but I managed to find what each of those codes mean. I'll write them below and with any luck, i've helped you get you your answer :).
F2=Which Filtration Cycle it's set to: 2hours per 12 Hour Cycle.
SL=In Sleep Mode, the heating temperature should stay within 20 degree's Fahrenheit only during Filtration Cycles. If this is not the case, the temperature is fluctuating and not current. The display will then show a solid "SL" in the display.
For further information, you can look at this mini manual here:
http://www.spacare.com/productimages/pdfmanuals/Balboa/Duplex_and_MiniOval_Ref.Pdf
And I found out where you can contact the people who do specific handling s to this filtration system, and they are located here:
http://www.spacare.com/balboasuvsystemcontrolboxwm-7techonology.aspx
About your product with info, listed here:
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Posted on Jun 19, 2011
Balboa hot tub m7 wont power on at all
Either the spa is incorrectly wired or one of the fuses is blown in the spa pack. Typically this is due to your electrician wiring the spa incorrectly and blowing the fuse on accident.
Aug 06, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
Hi have problem with canadian spa (balboa mrspa1) control panel digital reading when turned on goes to OH,circulation pump will not run
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Mar 30, 2011 | Balboa Instruments Duplex Digital Panel 2...
Looking for Balboa 2000 LE Hot Tub manual
Try this link for the M7 Series controls, which covers the 2000 LE series.www.sunraynorge.no/pdf/balboa%2050hz_eng_m7.pdf
Aug 02, 2010 | Home
My hot tub pump will not stop running even after it has reached temperature and completed it's cycle. I have a Balboa Instruments control unit. Any suggestions?
sound like you have the filter cycle set to fc means filters all the time try to push temp button and then pump button. in sequence you want it to be f2 means filters 2hrs every 12 hours
Nov 22, 2009 | Sys BALBOA SUV SYS 5.5kW W/ 120V 1.OHP...
When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
May 24, 2009 | Balboa Instruments Duplex Digital Panel 2...
Pool & Spa Logo
131 people viewed this question
Top Balboa Instruments Pool & Spa Experts
russlakeside
Level 1 Expert
Are you a Balboa Instruments Pool and Spa Expert? Answer questions, earn points and help others
