Question about Sport & Outdoor - Others
Directions to install trampoline net - Sport & Outdoor - Others
Parts for 6.5 Ft Funtek USA trampoline
Hi ,
We require a new net for this 12-14ft trampoline?
How much and can you supply these for the funtek trampoline?
Kinda regards
Cian
0416559159
Sep 03, 2014 | Funtek USA Funtek Trampoline and Enclosure...
Telstar trampoline
Go to the local steel supply shop or exhaust system shop as the steel tube will available there.
May 17, 2013 | Sport & Outdoor - Others
Do safety nets on trampolines stop children from getting hurt?
A core part of gymnastics involves being able to both understand how the ... Safety nets prevent users from bouncing off the trampoline surface and onto ... In powerful wind storms, trampolines with safety nets can be tossed around ... The majority of the injured are children jumping on trampolines in the home environment
Aug 20, 2012 | Sport & Outdoor - Others
Can I get a trampoline cover for my circular trampoline even though I have an enclosure all around it?
Good question - it depends what kind of enclosure you have. If yours is netting which is fitted to the frame, there is nowhere to clip the cover. But if you have an enclosure which is attached by bungee cords, you can fit a cover.
I need an instruction manual for my 14ft trampoline with enclosed netting
May I get the make and model # of the trmpoline to help you more.
Apr 28, 2010 | Trampolines BQC1620
How do fix trampoline net, stitching ripped
Take your net to a commercial upholstery shop; they have the correct sewing machines and, threads to repair these properly.
Mar 30, 2010 | Trampolines BQSM20DL
Trampoline Net is torn
hi i was wondering if u got this fixed and if so how did u do it as i have the same prob
Sep 30, 2009 | Trampolines BQC1620
Tears in a trampoline net
You can use a patch, but most trampolines fabric is made to stretch, and a patch interferes with that often transferring the stress to another location causing additional wear on the fabric. Best thing to do is to simply replace the entire mat. The weather is pretty ******* them.
Nov 26, 2017 | Trampolines BQC1620
Trampoline net
Hope this helps. The trampoline net will either have a sleeve for flexible poles to form a ring at the top or there will be at least four obvious "loops" to hang from the poles. Then you need to sew the net to secure it to the mat/trampoline itself with rope. A good idea to buy new rope to do this as it wears with use. I have replaced my securing rope with "tie-down" rope from the sporting good department. The soft nylon kind seems to wear better. To sew: use a good knot to secure it to the underside of the trampoline (spring/Loop) then simple go through the net at the bottom skip a few holes come back through the net and go down around the bottom of a spring hold. repeat all the way around.
Apr 05, 2009 | Trampolines BQC1620
Sport & Outdoor - Others Logo
104 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
