Question about Home
American Whirlpool Jupitor model cuts off and often will not start the process.
  • 119 Answers
Sounds like the pump is overheating make sure pump motor is not obstructed by insulation I have seen people put insulation around pump motor to quiet it down but the pump needs air to keep cool
Posted on Nov 15, 2009
I have a American Standard Corner Whirlpool Year 10-10-03 Model 752857-300 When I push down The air switch button down The whirlpool come on But when Push again it will not cut off I check hose going to...
t sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Sep 27, 2013 | American Standard Home
Water heater heats water and then cuts off. I replaced the lower element with a guaranteed for life element. It still heats up and cuts off. There is a control box on top that allows for an easy reset. ...
1) Bad thermostat or thermistor depending on model.
Whirlpool/Craftmaster/American energy smart has control box on top, and you can order parts from Whirlpool.
2) Copy following links to help identify product.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
3) Add a comment with more detailed information:
You have electric water heater.
Unknown brand, possibly energy-smart.
Unknown control box.
Cut off? Do you mean 'reset' is tripped?
4) Whirlpool energy smart requires 10 gauge wire and 30 amp breaker.
Control panel may not function with undersized electric supply.
Control panel has blinking-light errors ... if no error code then maybe the control box is bad.
Jan 18, 2013 | Water Heaters
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Have a kenmore 80 series washer that does not cut off water after tub has reach it's level and overflows
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds like a defective Water level Switch:
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the following for how to access the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=400785c7cf87579d23b319fdde9a00ce
The following diagram may also help locate the components.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=138
Mar 28, 2010 | Kenmore Washing Machines
I want to buy an anode rod for my whirlpool water heater. Mod # E2F80HD045V. Cannot find the part number.
The part you need is actually the following as it was made for Whirlpool by AMERICAN WATERHEATERS:
Part for AMERICAN WATERHEATERS, Model # E2F80HD045V
Number: 4710185 Category: Plumbing and Heating Length: 53.90 Width: 1.10 Height: 1.00 It is sold by Sears and is available for $17.99.
Good luck with your repair!
Mar 13, 2010 | Whirlpool Water Heaters
Considering buying a car guy says engine cut out when brake was applied, says it may be fuelpipe break. how much would this be to fix? its a 1996 jeep cherokee
stay away.. from this deal!!! his answer if from Jupitor. or mars... this unit has major electrical problems and i would suggest it was a insurance right off!!!
Feb 26, 2010 | 1996 Jeep Grand Cherokee
Whirlpool pump only buzzes.
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
Jan 13, 2009 | American Standard 2770.018w.020 Cadet...
Flickering display panel on Whirlpool american style fridge/freezer
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
Jul 16, 2008 | Whirlpool Refrigerators
Home Logo
55 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
