Snark tuner manual - Office Equipment & Supplies
Where can I find a manual for Kenwood Tuner kt-57?
Is it a tuner only? If so you will need a power and or just a receiver with speakers. A tuner only has no power output for things like tvs.
Mar 25, 2016 | Kenwood KT-57 Stereo Synthesizer AM/FM...
What are the tune r numbers
For 6 STRING GUITARS, tune strings in
ASCENDING ORDER: Target Hz
For 6 string guitars. Tune in ascending order
First LOW E . . . . . . . . . . . . . . . . . 82.4
Second A . . . . . . . . . . . . . . . . . 110.0
Third D. . . . . . . . . . . . . . . . . . . 146.8
Fourth G. . . . . . . . . . . . . . . . . . 196.0
Fifth B . . . . . . . . . . . . . . . . . . . 246.9
Sixth HIGH E. . . . . . . . . . . . . . . 329.6
For 4-5 string BASS GUITARS, tune strings in
DESCENDING ORDER: Target Hz
For 4 and 5 string Bass Guitars
First G . . . . . . . . . . . . . . . . . . . . . 98.0
Second D. . . . . . . . . . . . . . . . . . . 73.4
Third A. . . . . . . . . . . . . . . . . . . . . 55.0
Fourth E. . . . . . . . . . . . . . . . . . . . 41.2
Fifth B (if 5 string) . . . . . . . . . . . 30.95
The manuals are here.
http://www.snarktuners.com/contact-service
Jan 16, 2016 | Snark Clip-On Guitar & Bass Tuner
What are the snark tuner numbers?
If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jan 16, 2016 | Televison & Video
How to use a super snark clip on tuner for an
Not sure which model clip on tuner you have got. Best to go to this site and scroll down to the user manual that you need.
Contact Service snark
Sep 11, 2014 | Music
Does this model DVD/VCR recorder have an analog tuner or a digital tuner?
Is there a manufacture date on the back of it. The Commission's digital tuner rule specifies that as of March 1, 2007, all new TV sets must include digital tuners. I believe that rule follows when it comes to DVD players with built in tuners. If you bought this before that date then most likely its analog. I see in the owners manual has no listing for a digital tuner. So I would come to the assumption that its analog tuner. Hope this helps!!
Jan 14, 2011 | LG LRY-517
Does my model have a built in tuner please Sanyo   LCD32xR8DA  television as the manual was lost this is all the info i have .    flat panel television
Yes your unit has a built in tuner:
Tuner Tuner Type HD Digital
Included Tuner Style Inbuilt
Pal Reception System B/G check this for more info
Sep 11, 2009 | Televison & Video
When ever i start tv tuner program(honesttech TVR) my pc get freeze i have SAA7130 TV tuner installed in my pc
is this tuner new or old and is ur pc new or old. if ur pc is old then place the tuner in another pci slot and then check out if that doesnt work then check the system requirement of the tuner that is in the manual and properly configure ur pc according to the requirement
Sep 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips intergrated RDS Tuner FT980
mail me at siegfriedvik@gmail.com and i'll send you the repair manual;i also have one that has a similar problem and finally i found the manual
Jul 07, 2009 | Philips Audio Players & Recorders
Digital TV
It does have a tuner built into it.
It is not a hd or digital tuner.
manual
<A href="http://www.uwsp.edu/cps/facilities/classroom/manuals/VCR/PVD4752.PDF">http://www.uwsp.edu/cps/facilities/classroom/
manuals/VCR/PVD4752.PDF</a>
Feb 23, 2008 | Panasonic PV-D4752 DVD Player / VCR Combo
14 people viewed this question
jasbo
jasbo
