Question about MotorGuide 930011020 TR82L FB DIGITAL 45" 24V 21MT TOUR SERIES BOW MOUNT TROLLING MOTOR
Motor guide foot presure adjustment
Petal is hard to operate
Were do i plug in foot petel on a 6267
*pedal = something your foot goes on.
*petal = part of a flower
Take a look at page 4 of the manual in the link. It shows it disappear into a slot in the side.
Singer 6267 Operator Manual Page 4
Apr 29, 2018 | Sewing Machines
Have a brother sawing machine it just humms when i press ladel
would be something wrong with the foot petal or the motor, make sure the foot petal is snuggly connected into the plug of the machine, and if it is, then the machine needs to be checked
Mar 20, 2014 | Singer Sewing Machines
Foot petal is not working and it is plugged in.
Is there power, does the sewing bed light come on? If so there is probably a fault with the pedal. If you are practical you can open the pedal and fit a volt meter across the terminals to see if the voltage increase when the pedal is pressed.
Feb 11, 2014 | Singer 7422
My cruise control will not engage. I can mechanically lift the brake petal with my foot and everything works perfectly; however with I release the upward pressure the cruise disengages.
adjust the brake light switch on the top of the pedal. Should have a screw and nut style adjustment. Make the button on the switch compress more on the bracket. Then Drive.
Aug 02, 2013 | 2007 Cadillac DTS Sedan
Husqvarna riding mower modle yth20k46 that move very slow
The link rod from the petal to the transmission straightened out at the rear bend. Take it off and bend it slightly further to make it go forward faster. The 1/2" nut above where the rod connects to the transmission is adjustable to set it where it doesn't move when your foot is off the petal. Loosen it a bit and you can move the petal slightly forward or backward to adjust it. Depending on how much you bent the rod it won't take much adjustment. Re-tighten and try it out. It may take a few tries. Good luck!
Mar 17, 2012 | Husqvarna Garden
My brake light won't turn off even if my foot
Your brake switch is just hung up. it is located directly above the brake petal and is attached to the petal bracket-use a flashlight and get down low enough to see up under the dash where your brake petal is, it will be hooked onto the petal bracket-just move it, it is probably just mis-aligned.
Jul 20, 2011 | 1990 Toyota Tercel
The pressure foot will not run the machine you have to push very hard the the machine goes very fast.
meed a little more info, make sure the pressure foot is in the down position,
what do you mean you have to push very hard, are you pushing on the fabric to fo under the needle,
if the presure foot is down, check the manual on how to adjust the pressure it may be to tight and need to loosen it
Aug 27, 2009 | Brother LS-1520 Mechanical Sewing Machine
Hand operated free start wheel is not turning
Try holding down the foot pedal & turning the wheel at the same time.
Dec 09, 2008 | White Sewing Speedylock 1600 Mechanical...
MotorGuide 930011020 TR82L FB DIGITAL 45" 24V 21MT TOUR SERIES BOW MOUNT TROLLING MOTOR Logo
27 people viewed this question
Top MotorGuide Boating Experts
Mike
Phil Walker
Phil Walker
Angel Joseph Jr.
Angel Joseph Jr.
Are you a MotorGuide Boating Expert? Answer questions, earn points and help others
