Question about Husky 1/4 in. Air Compressor Filter HDA70403AV
On top of the HDA70403AV there are machined holes for mounting and what screw type and size do I need?
How do I install a tv on my wall
First of all find out what size mount is on the TV. On the back of the TV you should see 4 screw holes to take the bolts of the stand. You can measure the space between the holes. Then you can search for a mount that will take that size. If the TV is big you will need a very strong wall mount.
When you get the mount it should have instructions for mounting it. But make certain the wall you are fixing it to can take the weight and is stable. Fix the mount to the wall, make certain that you use the correct screws and plugs for the screws. You should be able to tell if the mount is secure enough. If you have any doubts, get somebody in to do it. The mount will come with the correct fixing screws for the TV. You will need two people at least to fix a smaller TV to the wall and two people to hold a big TV while a third screws the mount to the TV.
Feb 10, 2017 | Televison & Video
Screw size for mount and tv un32f5500af
This TV is VESA mount compliant with a spacing of 200MM x 200MM. the mount holes are M8 1.25 and about 23MM deep. 3 of the holes are recessed and one hole is near surface. Adding a 2-3 MM margin for a typical washer and the mount itself, M8 1.25, 25MM screws might be the best to mount this TV.
I am using the Sanus simplicity SMF3 mount (bought from costco). The spacers provided with this mount are 22MM which makes the supplied M8 35MM screws too small with the spacers. Without the spacers, the supplied M8 16MM screws are too small. With spacers, I think the screw size should be M8 45MM and without spacers it should be M8 25MM
I am thinking a vinyl washer might be a good addition to the assembly (with my sanus mount).
Found this site useful to understand the screw dimensions.
http://www.fastenermart.com/html/metricsizes.html
Dec 22, 2013 | Samsung Televison & Video
I have a 37
Metric M5 screws, the wall you buy will be supplying with mounting hardware.
http://www.toptvmounts.com/
http://www.mountsdirect.com/
http://www.mountsmadesimple.com/
Just Google " wall mount for xxxxx"
Nov 24, 2009 | Televison & Video
We have a LC427SSX and want to mount it on the wall
The thread size is standard, just a metric standard. To attach the Sylvania LCD427SSX to the wall mount bracket you'll need (4) metric 8mm machine screws with a 1.25mm pitch. You'll find them at your favorite neighborhood hardware store with the designation M8 1.25x40mm. (40mm long...the 30mm would be to short)
Jul 09, 2009 | Sylvania LC420SS8 LCD TV
Has no mounting screws what type do they take or are they standard
Most of these tv's use the 1/4-20 machine screw, for example, has 20 threads per inch and a 1/4 inch diameter. I would recommend that you stick a piece of wire into the screw hole to determine the length that you need and start with this size screw. If it fits nicele and snugs down you will know you have the correct size.
May 07, 2009 | Televison & Video
What size are t top mounting screws on the GE JVM1350 spacesave
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Here's a picture of three screws:
Apr 05, 2009 | GE Microwave Ovens
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
No screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Husky 1/4 in. Air Compressor Filter HDA70403AV Logo
37 people viewed this question
Top Husky Air Tools & Compressors Experts
Lawrence Oravetz
Gil Shultz
ray gallant
Are you a Husky Air Tool and Compressor Expert? Answer questions, earn points and help others
