Question about Frigidaire Washing Machines
Can I bypass safty switch on stackable fridgaire washer/dryer. After it broke and fell off I when I put it on spin cycle water went on floor.
  • Frigidaire
    Frigidaire May 20, 2014
    Good Afternoon Friend, I understand that you are putting your Frigidaire washer on the spin cycle and water goes all over the floor. I also see that you want to bypass the safety switch. While I do not recommend bypassing any safety switch, I would please need the model number of your appliance to better assist. Looking forward to hearing from you. WP
  • Frigidaire Master
  • 5,323 Answers
Yes u can but remember if u have children its a safety issue. the switch is not that expensive but u can do it see pics
can I bypass safty switch on stackable fridgaire w - 24445330-vy3qd1rc3oikbunb5kfp1hkm-3-0.jpg
24445330-vy3qd1rc3oikbunb5kfp1hkm-3-2.jpg can I bypass safty switch on stackable fridgaire w - 24445330-vy3qd1rc3oikbunb5kfp1hkm-3-5.jpgt/uploads/images/24445330-vy3qd1rc3oikbunb5kfp1hkm-3-5.jpg" alt="24445330can I bypass safty switch on stackable fridgaire w - 24445330-vy3qd1rc3oikbunb5kfp1hkm-3-9.jpg"h_mi" />
Posted on May 15, 2015
vest6
  • 196 Answers
SOURCE: Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Posted on Jan 12, 2008
  • 116 Answers
SOURCE: Frididaire FLSE72GCSA stackable washer dryer
It is possible that the belt has come off or the lid latch is no functioning.
First unplug the machine then remove the two screws from the front lower edge of the washer.
The front panel will lift up towards you at a 45 degree angle. The latches will release than the entire front panel can be place out of the way.
The lid latch can be seen on the underside of the top panel to the right, check that the wires are not loose.
You will see a large motor mounted upright near the base this should have the belt around the pulley to the bottom of the tub assembly. Check for obvious damage
Outside of this you will need a repairman for help.
Posted on Jul 28, 2008
Maytag317
  • 1136 Answers
SOURCE: stackable w/d will not drain or spin
You will need to replace the switch I am afraid. If I had your Model # I could get you the part # . If you would like to order a swtich, I can give you my web site address
I would appreciate if you would rate my prfomance here because I am new to this site. Any feed back on how I am doing would be helpful.
Thanks
Vic
Posted on May 09, 2009
SOURCE: mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Posted on Jun 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: balancing problem Frigidaire stackable front load washer/dryer
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
My GE stackable washer is pouring out water while filling up, when spinning makes horrible noise and tub goes crazy
The issue is that a shock or spring that balances the tub has come loose and pulled a hose off when it broke. So the shocks or the springs are bad. The hose might be able to just be put back on.
Feb 23, 2015 | General Electric GE 5.4 cu. ft. Large...
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
Feb 21, 2010 | Maytag LSE7806A Top Load Stacked...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Wsxh208fww front load stackable washer, spin cycle won't work
It most likely has a bad door safty switch. This goes out and the cycles will not run.
Jun 15, 2009 | GE WSXH208A Front Load Washer
Mle2000ayw Stackable washer/dryer not washing, spinning
Apr 13, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
