My new washing machine wont fill and the soak light is out. we had a brown out two days ago
  • 79 Answers
This may help, if your machine is electronic, try disconnecting the power cord for 5 minutes, if this doesn't do it, the brown out has caused a lt more problems.
Posted on Jun 24, 2009
We have a LG He washing machine. It is 3 years old and get light use. Recently after each use the clothes are covered with brown soft specks How can we deep clean out machine?
hi David.
  1. Fill the washer using the highest load size, hottest water setting, and longest wash.
  2. Open the lid and as the washer tub fills, add a quart of white vinegar (or bleach). ...
  3. Next, add a cup of baking soda. ...
  4. Meanwhile, remove any parts you can and soak them and clean nooks and crannies under the lid.
More items...
How To Clean a Washing Machine ' Apartment Therapy
https://www.apartmenttherapy.com/how-to-clean-a-top-loading-washing-machine-apart...
How do you clean a front loading washing machine
Pour the vinegar into a measuring cup and head over to your washing machine.
  1. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. ...
  2. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue.
how to deep clean washing machine Google Search
Dec 03, 2017 | LG Washing Machines
Why is the SP light flashing when the machine has filled with water and is ready to go
sp is the code for stand by or pause
so if you have set a soak period then it will stay there until the soak period has finished
if it is sp and you have pressed pause/start extra time the machine is in pause mode until you press start again
Sep 29, 2016 | Simpson Washing Machines
My FP washing machine has starting leaving brown sludgy marks on my clothes. Do I need to descale the machine? Im in New Zealand and the water isnt particularly hard. Thanks for your time, Emma
I'm guessing you use fabric softer....Get some finish dishwashing powder and put a wash on with high water level with no cloths in it. let it do it's normal wash but before it drains any water out, pause the wash let it soak over night. next day unpause it and let it finish. Repeat if needed and do the same thing again with out any dishwashing powder in it to make sure it rinses all the soap out.
The black sludge is cause by using fabric softener. The costic in the finish powder will eat in to the sludge and soften it. If its really baked on it my need to soak for longer, more powder or it may need to be stripper and cleaned.
Mar 22, 2011 | Fisher and Paykel Washing Machines
My Kenmore top load washing machine is stuck in
sounds like ur pump has gone out totally and the controller is bad cause its not filling the tub or is it if it is and just wont pump it out u have a bad pump
Feb 25, 2010 | Dryers
Got a hec washing machine its the 5th time it has broken down warranty ran out 3 days ago it overfills with water and wont do a cycle
the fact that the machine has broken down five times inside the warrenty i would suggest you contact trading standards as i feel you would have recall on this the fact that the warrenty run a few days ago does not really matter and could be argued as to the problem sound like a faulty diaphram switch this controls the water fill good luck
Jan 16, 2010 | Washing Machines
Bosch Classixx 1200 wont start. Ready light is on, door is firmly shut, but start button does not do anything?
these things can be confusing! you may have it set on 'delayed start' or 'soak'- check the other indicator lights! 'soak' would fill and pause for a while, while 'soaking'- 'delayed-start' can be set for an 8 hr. delay on our fridgidair front-loader. don't know about the bosch!
check settings. if ready light is on, there doesn't seem to be a problem with door latch.
good luck!
Oct 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Indesit W123 washing machine
it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
Mar 31, 2008 | Indesit W 123 Front Load Washer
Smartdrive 703 Model Washing Machine Leaving brown stains in clothing after some wash cycles. Stains are small and seem to be something coming through to the clothess from the slits in the drum holes. ...
if you do cold washs all the time you get a build up of sludge between the drums you need to fill it with hot water and let it soak for a few hours and then put through a high wash to rinse out,no clothes.Or you can remove the drum and wash it .hope this helps
Mar 14, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
