Question about Bosch Nexxt WTMC3321US Electric Dryer
Bosch dryer making rumbling /grinding noises low frequency
Its just a little over two years old. Still heats and turns but makes this new noise
  • 146 Answers
You might want check the rollers that tub rides on they are in the front lower part of the dryer, or the belt that turns the tub.
Posted on Jun 24, 2009
KitchenAid microwave KHMS1555L makes a loud noise when initially turned on. Does not heat at all. Does anyone have information what the problem may be? 10 years old. Is it worth fixing?
It really sounds like you have 2 problems, neither of which is likely to be fixed, unfortunately.
One is the noise, and it should be a problem with the wheel that drives the turntable.
There is a belt driven pair of wheels, and I think yours is broken. Then, the lack of heating, is likely the "magnetron".
That is the large and heavy unit that makes the mircrowaves to cook the food.
Very few places fix these anymore, because the cost of the parts & labor will be much higher than buying a new one.
God bless our efforts.
Mar 14, 2016 | KitchenAid Dryers
Bosch WTA 3510 uc/13 FD 8203 compact dryer is very loud. Motor is okay. Just changed the main pully. Belts are okay. Still is a loud rumble when operating. Any ideas? Rear bearing appears to be ok
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Oct 09, 2014 | Dryers
Noises
After 15 years of service I imagine it will be hard to get the parts you want to repair it.. Newer machines may not dry as quickly as the older types but they use less power to do so.. Consider a new machine for the sake of the economics of the problem
Jul 26, 2013 | Maytag Neptune MDG5500AW Gas Dryer
Dryer makes loud grinding noise when heat turned above low.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 18, 2011 | Amana Dryers
LG Model DLEX7177RM makes a rumbling noise upon start up like a bad bearing or gear drive sound. Noise is cyclic at dryer spin speed. Dryer is only a couple years old. Are there any recalls, warranty...
heatman101
Asker
Jan 02, 2011 | LG Dryers
Our heavy duty Inglis dryer (maybe 4 or 5 years old) is making a loud noise. The drum still turns. The heat still comes on and the clothes will dry. But the noise......Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 08, 2010 | Dryers
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
Amana dryer makes rumbling noise when the drum turns
heatman101
fsdjds
Nov 16, 2009 | Amana ALG443RAW Gas Dryer
Grinding noise
In my humble opinion, a dryer making a grinding noise is worth repairing. Possible Problems:
Worn Drum Rollers (Very Likely): More of a thumping / grinding sound. Replacing drum roller supports is considered to be a routine "normal ware & tear" repair with parts costing about $15 - $20 or so. Its' kinda like a tune-up for a vehicle. The rollers can be located in a couple places, but are typically located on the inside rear of the drum; upon dis-assembling the dryer.
Broken/Loose Blower Fan Wheel (Likely): The blower wheel can become loose or brake off the motor shaft and can make a "rumbling / grinding sound and can run about $15 - $25 for the part. The degree is difficulty when repairing a little high, but is commonly performed.
* Note: Removing and threading the blower wheel is reverse to prevent the fan blower from natually spinning/coming-off "Righty loosey, lefty tighty"
- C
Jan 27, 2009 | Maytag Dryers
Dryer making a grinding or rumbling noise when it is on
i would bet you hae a dented top of the dryer. thats what is hitting the drum causing the noise. if you put something heavy on top of the unit then the top could have bent down and is now hitting the drum when it runs. and heat as it runs will make it worse.
if yo can, pull the top up and re-shape the top so it doesnt hit th drum and then dont let the top get pushed down again.
Jan 15, 2009 | Estate EED4300SQ Dryer
Bosch Nexxt WTMC3321US Electric Dryer Logo
373 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
