I have a GE 46GW948 and it seems to be stuck on some kind of 3d mode. I can see two sets of words. One is red and the other is blue?? How can I fix this?
2 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: I have a GE Big
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Feb 21, 2011
I have a GE Big Screen Tv with Guide plus. model number 46GW948. my son got into factory settings and set the tv in some sort fo 3D setting. the red, green and blue need to be adjusted. Can you help me...
  • Screen looks 3D
69189a5.pngSOLUTION
Feb 12, 2011 | GE 46GW947 46" Rear Projection Television
Just got this t.v from my dad. It is a pt5492 model. It has kind of dark yellow picture with alot of red. He was told it might be blue light is bad? Can I fix this myself?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 16, 2011 | Akai PT5492S 54" Rear Projection...
SCREEN IS HIGHLIGHTED RED, ALL WORDS READ IN RED AND THE PICTURE IS BLURRY ON PHILIPS MAGNAVOX 9P5034C101
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Aug 13, 2010 | Televison & Video
Lookslike the picture is in 3d and when i try ti use magic focus
  • Screen looks 3D
Jun 02, 2010 | Hitachi 57F500 57" Rear Projection...
Red and green lines, kind of 3D looking???
  • Screen looks 3D
Feb 28, 2010 | Hitachi 43UWX10B 43" Rear Projection...
All three colors have seperated and appear kind of like a 3d movie. Is this something we can fix on our own? We have experience with soldering and minor electrical repair. Any help, guidance, repair...
  • Screen looks 3D
Feb 26, 2010 | Samsung HCL552W 55" Rear Projection...
The picture looks 3D
  • Screen looks 3D
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Screen projector un aligned
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Green shadowing
  • Screen looks 3D
Jan 06, 2009 | Hitachi 57SWX20B 57" Rear Projection...
GE 46GW948 42" flat Screen
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put off tv for 15 minutes & then put on again. do not move when it is on. please let me know if it gets ok or call tech to degauss it . it is hardly 5 minutes job. good luck
Oct 02, 2007 | GE 31GT660 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
