Question about HP DeskJet 810c InkJet Printer
Can't get it to print out a test page or anything I don't have a install disk and went thru the wizard to set it up using a usb cable set as default and still can't get it to print
  • mnguy7764 May 11, 2010
    Go here:http://h10032.www1.hp.com/ctg/Manual/bpd... To print a test page, are you going to printers, right clicking on the printer and go to properties, then print a test page?
  • 146 Answers
Is it HP if so just go to web site download drivers.
did go to by computer left click, go to properties and see if the compute see it.
Posted on Jun 23, 2009
My M1522 MFP printer is working it used to be network shared but now I want to print direct from laptop to printer using usb cable (I no longer want it networked). It went to restor defaults and cleared...
When you changed from Network to USB cable, one or both of two things may have occurred.
First check your printers list in the control panel. You may find you have two apparent installations of the device. If so try a test page from each install and record the port settings for the one that responds. Delete the other and re-test. If the machine fails to print on any setting, delete ALL installations for the device and re-install from fresh with the USB cable. You may also need to go into the settings on the device itself and disable any network settings.
Oct 16, 2017 | HP LaserJet M1522nf Multifunction Printer...
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
Cannot print
Try first unplugging power cord, pulling out cartridges, and putting them back.
Restart the computer.
Ensure you removed the cellotape strip from new cartridges, and that cartridges are properly installed.
Ensure that the printer is set as default printer in Windows.
Print a test page from control panel>>printers>>properties.
If all the above does not work, try a replacement USB cable, just in case, then proceed reinstalling the driver software. Follow the method below to reinstall software:
To reinstall the software you can use the disk that came with the printer, or download the driver software:
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthe file, double click on the file , then if you getintroubles,followthe instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Nov 09, 2008 | HP Deskjet F340 All-In-One Printer
Is the printerdriver easy to install?
Yes, follow this steps
Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers:
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Parallel port printers Windows 2000 and XP
  1. In Windows XP default view, from the Start menu, select Printers and Faxes, and then double-click Add Printer. In Windows XP Classic view, or in Windows 2000, from the Start menu, select Settings, then Printers, and then double-click Add Printer. This will start the Add Printer Wizard. Click Next.
  2. Select Local printer or Local printer attached to this computer. Click Next.
  3. Select the LPT port.
  4. Select the manufacturer and model for the printer you are installing. If you would rather use the driver disk that came with the printer, insert that disk and click Have Disk, and then browse to the driver disk and the proper folder. Click Open, then OK. Sometimes at this point, you will be asked if you print from MS-DOS programs. Most people can safely answer No here, but if you print from any DOS-based programs, answer Yes.
  5. Windows will offer a name for the printer that you may change if you like. If this is your only printer, or you wish to use this printer most of the time, select Yes to make this the default printer.
  6. You will be given the option to share this printer on the network. Unless you specifically want to do this, select Do not share this printer. Click Next.
  7. Make sure the printer is connected and turned on, and then answer Yes to print a test page. This will ensure that your printer is working. After the page has printed, click Finish. Your printer should be ready to use.
Oct 28, 2008 | Lexmark Office Equipment & Supplies
Is it difficult to install?
Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers: USB printers (Windows 98, Me, 2000, and XP only)
LexmarkZ600 will not print I put in new ink cartridges.
None : if you have Vista, many old models will not work unless they are Vista compatible.
How do i set it up?
In Windows, how do I install my printer? Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers:
Oct 27, 2008 | Office Equipment & Supplies
Does IOGEAR GPSU21 work with Vista?
before running the PS Wizard in Vista, right-click on the icon for PS Wizard and select "run as administrator". This will clear the bind errors and wrong segment errors many times - this only applies to vista.
May 09, 2008 | IOGear GPSU21 Print Server
HP LASERJET 1100 WONT PRINT
go to Start, Settings, Control panel, printers and faxes is your printer there? is there a checkmark? no, then right click and set as default, put your mouse over it does it say Ready? no, then change cable.
send test page, it should print, if not the USB or Parrallel input of your printer has a problem.
Aug 14, 2007 | HP LaserJet 1100 Printer
HP DeskJet 810c InkJet Printer Logo
126 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
