Goodman problem with new mbvc1600aa only get low speed and green light blinks 6 times?
Orbixx
  • 133 Answers
SOURCE: No power
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
Posted on Sep 06, 2007
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Aug 12, 2008
  • 195 Answers
SOURCE: My SXRD 60
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
Posted on Oct 10, 2009
  • 556 Answers
SOURCE: 6 red blinking lights
You have a bad thermal fuse.
Posted on Oct 23, 2009
SOURCE: i turn the tv on the green light blinks 5 times
this isn't a solution, I have the same issue. Mine started doing the 6 red blinks yesterday. How do I fix it? I've changed the bulb before...
Posted on Jun 24, 2010
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Panasonic tx-32lx6017 tv blinking
IIC bus clock and/or data lines low at power on 06
6 blinks denotes this. The main digital board should be troubleshooted. If you wish to know more about the blinking codes to Panasonic TVs, check this link.
Feb 25, 2013 | Televison & Video
My split type 2.5hp carrier express ion shuts off (including the condenser) after five minutes of running, the indicator light blinks during this time...it restarts again after awhile, then shuts off again...
How many times is the light blinking? Also is the light red, yellow or green? The light blinking is telling you exactly what has failed.
(# of RED blinks first)
1 High Pressure Protect
2 Indoor coil freeze protect
3 Low pressure protect
4 Compressor discharge protect
5 Low pressure/Overcurrent protect
6 Indoor-outdoor communication error
8 Hi-Temp protect
10 AC Voltage Low
Each of these has maintenance required steps to resolve the errror. Let me know how many blinks your getting...
Kelly
Apr 25, 2011 | LG Heating & Cooling
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
6 blinks
sounds to me like i wish i could find out if this is new install or if the electric has been changed recently,,,sounds like reversed polarity on the plug,,,which means the white and black wires need to be swapped. If there has not been change recently than u need to see the other post i made on goodman about the combustion fan motors and there types and fixes. But almost certain that is reversed polarity. good luck
Oct 23, 2008 | Goodman GMS90703BXA Heater
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Blinks 6 times
6 blinks mean low b error. you will ned to replace the g1 board
Sep 05, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
