Question about Garden
Model 12AKC290596 won't move in gear 1cub cadet self propelled mower model 997 problems
3 Suggested Answers
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
  • 93 Answers
SOURCE: Cub Cadet 997 self propelled mower with 6.5
Might be just a loose head, Check that first, are the bolts tight? If loose I would clean head and install new head gasket and torque to specs. (In inch pounds).
Posted on Sep 17, 2009
Cub cadet 173cc ohv engine is not self propeling
it is either the belt or cable. Remove the belt housing and see if the belt is in place and in one piece. move the propel lever back and forth with the motor off and see if the opposite end is moving like it should at that connection.
Jul 20, 2014 | Garden
How to replace the self propelled
Make sure the cable to the transmission moves freely. If all the cables and lever s move freely than it more than likey is an internal gear needs replacing.
Jul 15, 2014 | Poulan Pro 22" Self Propelled High Wheel...
Self propelled cadet mower locked up how to unlock
Check engine oil level first for proper level.If it has oil in it PULL SPARK PLUG WIRE OFF SPARK PLUG IF MORE THAN A SINGLE CYLINDER PULL ALL PLUG WIRES OFF. Put unit on its side and grab the blade and see if you can move it in either direction or if the engine is locked up.
Jun 11, 2014 | Cub Cadet Lawn Mower Deck Drive Belt...
Mower won't move
Judy sounds like an obstruction in the self propelled mechanism. Check underneath and make sure it's clear. If it's ok it may need a repair.
Jul 21, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Lawn boy self propelled mower won't move backwards
is it belt driven can you pull it back when it not running
Apr 11, 2013 | Garden
Cub Cadet 997 self propelled mower with 6.5 Kawasaki engine will not start. appears to have low compression
Sep 06, 2009 | Garden
What is causing slipping of rear right wheel on
most likely the gears that are inside the wheel hubs.
Jul 09, 2009 | Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
