Question about Samsung ML 2525 BW laser Printer
My samsung ML2525w remain on for 10 seconds an then turns off ,what could be the problem?
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
My samsung galaxy s4 wont turn on or charge
do not buy new battery...just connect to external power supply 4v 500 ma and after 10 min battery will be good
Feb 14, 2015 | Samsung GALAXY S4
AV1 remains in the upper left corner of the screen. Volume diagram remains in the center of the bottom of the screen. Both of these are on the screen all of the time.
This sounds like Screen-Burn which is very uncommon for an LCD TV.
You could try resetting the TV.
- Press and hold the 'Exit' button for 10-15 seconds.
- Follow on screen prompts to reset and retune.
Failing this it *Could* be screen burn.
Apr 26, 2011 | Samsung LN46A650 46 in. LCD HDTV
Hi, I have purchased Samsung Galaxy ACE S5830 whether it is possible to connect Samsung Bluetooth Headset WEP 450. Kindly inform me how to do it.
1 Enter Pairing mode. • Turn off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. • If you turn it on for the first time, it proceeds into Pairing mode immediately.
2 Search for and pair with your phone --> turn on the bluetooth with the widget on the home screen or in the settings. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will flash 10 times rapidly before entering Standby mode. • If the blue indicator light remains lit, retry pairing.
Mar 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
Earbud will not connect to lg env2
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
  1. Ensure that the headset is off (see Turning the headset on/off).
  2. Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
  3. Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a 'Setup', 'Connect', or 'Bluetooth' menu on your phone and then selecting the option to discover Bluetooth devices.
  5. Your phone will find the Samsung WEP200 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
  6. Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
wep200-5.jpg If pairing was successful, the indicator light will flash in blue 10 times rapidly before going to flashing every 3 seconds. If unsuccessful, the light remains on, and you will need to re-attempt pairing.
Dec 04, 2010 | Samsung WEP200 Headset
Connect trueblue bluetooth headset to Samsung Eternity cell phone
hold your finger on the call button on your blutooth device for around 6-10 seconds, this should make a couple of lights flash, when it does this it is active and ready to pair uo, then search, it will ask you for a code, usually they are generic and are prob the following 1234-12345-1111-11111-0000-00000-5555-55555 eiter one of these should work
Dec 26, 2008 | Cell Phones
Samsung HL5067W power cycling
It's simple. Your TV does not like you. Perhaps you need to speak kindly to it before you force it to watch BBC for hours. Buy it a scone.
Sep 29, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Hiya, I've got a samsung u900 and when the phone has been idle (slider down and keys locked) even for just a minute when some one rings me the keys light up but the screen remains blank no light or...
Adjusting the duration of the backlight
To adjust the duration, perform the following steps:
1. At the main screen, select Menu.
2. Scroll to and select Settings.
3. Scroll to and select Display settings.
4. Scroll to and select Light settings.
5. Scroll to and select Backlight time.
6. At On, press the OK key.
7. Scroll to one of the following options, and then select OK:
  • 10 seconds
  • 30 seconds
  • 1 minute
  • 3 minutes
  • 10 minutes
8. Scroll to Dim and press the OK key.
9. Scroll to one of the following options, and then select OK:
  • Off
  • 5 seconds
  • 30 seconds
  • 1 minute
  • 3 minutes
10. Select Save.
Aug 07, 2008 | Samsung Cell Phones
Samsung ML 2525   BW  laser Printer Logo
47 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
