Question about Refrigerators
Display is showing I/M sensor code. What does this
Display is showing I/M sensor code. Unit will not cool as a result. What does this mean and where is the I/M located?
  • 483 Answers
We would need more info as the model & make ..
however you could try replacing the heat sensor at the flip side of the machine..
Fame !
Posted on Jun 23, 2009
IE on screen what does that mean?
The codes these displays usually show that are hard to trouble shoot are:
88888 - This means the unit has suffered from dirty power or power surges and should be unplugged and plugged back in about 60 seconds later. This should reset the unit.
OF- Means the unit is in a Cooling OFF Mode, This is a power saving feature used by Retail locations. Some call it a DEMO mode.
PC-ER - unfortunately means your unit needs service.
IE - is a tough one, I would like to see it first hand but if everything is working correctly might possibly be a display error and it should be saying ICE - I have not come across this one in person.
Aug 06, 2013 | Samsung RF4287HA
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
Pentair MasterTemp 400 Stack Flu Sensor Reading Stuck
check gas pressure and for clogged burn tubes unit is overheating
May 12, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Error code F3 E5 when using self clean cycle
Error Code F3 - E5 - Oven temperature sensor (RTD) shorted (lower oven, if double oven)
Replace Oven temperature sensor (RTD) or Thermal Fuse.
Hope this helps.
Oct 08, 2011 | KitchenAid Kitchen Ranges
When I plug it in the screen shows EEE, and beeps continually. It is around 65 degrees in the area. Nothing clears it or stops the beeping. It worked great yesterday.
The error code E:EE means the breadmaker thinks the temperature is too cool i.e below 59 degrees F or 15 degrees Celsius.
As you say the temperature is actually 65 degrees - then this means that the temperature sensor on the Bread maker has failed and will need to be replaced.
The EEE code and beeping will continue until the failed sensor is replaced and as this is a component failure it cannot be reset unfortunately.
Thanks for using FixYa.
Sep 11, 2011 | Regal Ware K6725 Kitchen Pro Bread Maker
Onida split ac show only f8 in display. how to slove the problem
That code is usually a result of a leak in the system and the unit being low on charge...find/fix the leak and recharge the unit.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air ConditionerTrouble -Review the Possibilities
heatman101
Jun 21, 2011 | Heating & Cooling
We were getting an E4 but now we get an E2 but
I do know that the owners manual should show you what each and every code means? Some times the manufacture will paste a strip located on the panel of the indoor unit showing what each code means. If not, I would contact the factory on this. I know on Bryant, Mitsubishi splits, Day and night, (Bryants), Tranes, Lennox and most all others, do show in the manual and on the unit behind the panel. Try looking for them there.
Sincerely, shastalaker7
Oct 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
May 07, 2009 | Heating & Cooling
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
