Question about Craftsman 54 In. 26hp Kohler Turn Tight Hydrostatic Garden Tractor
Where is the fuse located on the craftsman 54 inch mower
  • 10865 Answers
SOURCE: What is the spark plug model number for craftsman YS4500 lawn mow
go to any auto parts store with your model info as they have a book which will tell them which spark plug is best for u.
Posted on Apr 16, 2009
  • 71 Answers
SOURCE: Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
Posted on May 02, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 95 Answers
SOURCE: Have 54 inch Craftsman mower deck that I am
Depends on how old the deck is. Some of the older spindles and mandrels were not made to came apart. The newer ones you can put the nut on the top threade to protect the threads and a couple of taps it should come out. If you have a model number you can got to sears web site aa they will have an exploded view. http://www.searspartsdirect.com/partsdirect/index.action
Posted on Mar 21, 2010
  • 6 Answers
SOURCE: My deck belt on my 54 inch craftsman mower keeps
have you solved your problem yet? was the belt bought from sears or somewhere else? do you have a diagram for the belt instillation? these are a few thing i would ask you. i belive your belt is a 196103 style belt the problem with this is that there several manufactures that call there belts a 196103 some ar 11/16 other are 5/8 wide and the range in length from 147-1/4 up to 148-1/4. next if you reverse the install order around the center spindle and tensioner it will have too much slack if these two things aren't your problem i would look for worn pulleys especially in the shaft of the bearings or a misaligned/bent pulley
Posted on Aug 20, 2010
How do I acquire a belt diagram for a craftsman 54'' mower deck?
Search for your model number on sears site. If 0 results, search google with your model number. Owners manual usually has diagram.
Jun 07, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
Craftsman 54 inch zero turn mower wiring diagram
Please refer this issue to Sears
Jul 06, 2013 | Garden
Fuses location for craftsman 26 hp 54" deck mower
Replace start fuse on right side of motor by oil drain plug.
May 04, 2013 | Craftsman 26 Hp 54" Deck Yard Tractor
26 hp 54 inch craftsman mower will not cramk over. sounds like turns over once than no more. replaced battery and same issue
try you and jump start the engine direct to the starter if you have a bad battery cable it will not carry the amps needed if still no luck remove the spark plugs to see how it cranks over if spins over fine you might have a bad compression release system on the cam shaft if fluid spits out the carb could be leaking into the engine
Jun 29, 2012 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Wiring schematic 54 inch craftsman
Get a owner's manual, they have one in it. Go to www.managemylife.com and get your manual.
May 25, 2012 | Craftsman Garden
My belt keeps sliding off i have a 52 inch deck 3 blades . need diagram
Your owners manual should have a diagram. If you don't have the manual, you can download one here. You will just need the Craftsman model number of your machine.
http://www.searspartsdirect.com/partsdirect/product-types/Riding-mower-tractor-Parts
Mar 23, 2011 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
My deck belt on my 54 inch craftsman mower keeps slipping off - it is a brand new belt
Jun 22, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
New Craftsman Garden Tractor died while working
you might want to check the fuse, located ynder the hood somewhere. also chech that all saftey interlocks are intact and not unplugged.
Jul 13, 2009 | Craftsman Garden
Apr 16, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 54 In. 26hp Kohler Turn Tight Hydrostatic Garden Tractor Logo
20 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
