Question about Plumbing
I have a Grohe Europlus Kitchen faucet. The base
I have a Grohe Europlus Kitchen faucet. The base of the faucet above the counter is loose causing it to rotate off center. I would assume there is some type of tightening mechanism on the underside but have a difficult view because of the disposal. Can you help me?
  • Anonymous Mar 20, 2014
    I need a grohe europlus zedra disassembled.
  • 68 Answers
There is a couple of plates with a little screw in the center that tightens up the plate got to tighten it up
Posted on Jun 27, 2009
Grohe alira loose on granite counter
Needs to be tightened from under the sink, may need a right angle faucet wrench, they are about $10, or you can try and snug it up by hand, hope this helps?
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
Why is my grohe alira kitchen faucet loose
There is a nut up under the counter its hard to see but tighten that . Most faucets come with a special tool fo hat but can be done with wrench
Why is my grohe alira kitchen faucet loose on a granite counter
Probably a loose fixture nut under the counter behind the sink.
Yeah ya gotta pull out everything and crawl up into the cabinet on your back and see if the nut (right up at the granite, above the hot and cold inlet pipes) is loose. If it is THEN you'll need to tighten it. Wrench, slip-joint pliers or a basin wrench. (probably basin wrench which is a specialized tool made for reaching up into tight places)
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
I have a brand new Europlus faucet with hardly any water flow. I had the first Euro faucet with good flow. Why is the water flow so low on a brand new faucet.
when you installed did any teflon tape or debris get inside? you can remove and reverse flush with hose and it may clear the blockage
Jul 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
Jun 28, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
May 21, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe ladylux faucet loose on counter.
Here is the manufactures web where you may request the information you desire concerning your faucet.
http://www.groheamerica.com/s/25_4060/page/modules/iframe/index.php?if_url=http://12.130.64.173/litrequest2.htm
Dec 10, 2008 | Grohe Plumbing
Plumbing Logo
824 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
