Question about McCulloch chain saw part / 213885
Where can I buy a ignition chip for a Mc Culloch 213885 coil Mac -95
5 Suggested Answers
  • 594 Answers
SOURCE: What is the oil-gas ratio and the bar oil for a Mc Culloch Mac130
You should be safe with a 32:1 mixture unless you are a logger. And any Bar Chain Oil should work fine.
Posted on Apr 16, 2009
dontbother10
  • 2220 Answers
SOURCE: mc culloch chain saw 742 manual need urgently
Both the OM and IPL can be found here:
http://www.mcculloch.biz/int/support/owners-manuals/
Just type "742" in the "Model Search" window and click Search. HTH
Lou
Posted on Feb 17, 2010
dontbother10
  • 2220 Answers
SOURCE: have a mc culloch chain saw pro mac 10-105. No
I do find a 10-105 could it be a 10-10S model 600111 follows:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/8f167f396637c29d88256c2e0073560e?OpenDocument
Change the plug and try it, very cheap insurance.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Rotating the flywheel in a darkened room with the plug removed and the ignition on may reveal a leaky plug wire. Often a little heat shrink tubing will stop any leaks.
Model "11-600111-06 (02 through 06 suffixes possible) follows:
http://www.ordertree.com/modelinfo/MCC/11-600111-06-PRO-MAC-10-10S-08%2F82-to-Current-IPL-216062-01/139.11-600111-06-PRO-MAC-10-10S-08%2F82-to-Current-IPL-216062-01.1.59.1.html
See the "Powerhead Assembly" item 11; part number 223708-01.
If you determine the coil is bad I found one here:
M & D Mower
http://www.m-and-d.com/parts.html
Coil
http://arinet.lookupparts.com/AddToBasket.aspx?Qualifier=MCH&Name=223708-01&Quantity=0&SellerId=1017594&Username=Default
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 12, 2010
suzukiracing
  • 200 Answers
SOURCE: what are the carb. adjs. on a Mc culloch chain saw model cs 38em
If it bogs down like it's getting too much fuel, turn the low side screw out about 1/8 of a turn at a time until it will rev without bogging. If it chokes down like it's not getting any fuel, you probably need to open up the high screw a little.
BTW, you can determine which screw is which by looking at the carb at the base of the screw...it will have a L for Low or H for High stamped near it.
Posted on Jul 19, 2010
Where can I buy a carburator kit for a Mcculloch chainsaw 3516 in toronto
I would start with a phone book looking under saw and ask if the shop services that brand. If not do they know who does. You could also try a web search for Mc Culloch.
Jan 20, 2014 | Garden
Mc Culloch power washer FH140A The "on/off"
easiest way to fix it, buy a new switch at a home improvement center, the two metal piece go on the bottom and the springs are on top of them, when the switch is in the off position the metal pieces are up off the contacts on the bottom and when on the on position the metal pieces make contact. Hope this helps Tim
May 28, 2011 | McCulloch 1400 Psi Electric Pressure...
What are the carb. adjs. on a Mc culloch chain saw model cs 38em
Jul 18, 2010 | McCulloch Garden
Have a mc culloch chain saw pro mac 10-105. No spark-need new coil? Do they still make and where might I find one?
M & D Mower
Coil
Ignition module gap
Lou
Mar 12, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Mc culloch chain saw 742 manual need urgently
Lou
Feb 17, 2010 | McCulloch Garden
After having my Mc Culloch sharpened
You may have the chain on backward. The teeth on the bottom of the bar have to have the sharp edge coming at you in order to cut anything. Hope this helps you, Jeepfxr
Jan 28, 2010 | Garden
No spark on Mc Culloch 110 saw
Remove the stop switch wire from the switch and check for spark (use a clean spare plug and the plug base touching engine metal), If nothing, trace the wire back to the ignition coil looking for worn insulation. Is this a magneto model or an all-in-one module? If a magneto, there should be points and condenser--check points gap (about 0.015") and condition. Check the core gap to flywheel magnets (I use card stock to set the gap). Try to wiggle the flywheel to check for crankshaft bearing looseness. If the ignition is an all-in-one module, check the core gap to the flywheel magnets. Otherwise replace the module. Hope this gets you running.
Aug 26, 2009 | McCulloch Garden
Mc Culloch Grass strimmer ( trim mac T 161) Spool stuck on ?
the spool should have a bolt or a black knob in the middle of spool it thread are backword
Jul 21, 2009 | Garden
Apr 15, 2009 | McCulloch Garden
McCulloch chain saw part / 213885 Logo
18 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
