Question about HP Photosmart 2610 All-In-One InkJet Printer
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
    Guru:
  • 224 Answers
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (my 8x10 photos have half a blue tint and half a - c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Posted on Jun 24, 2009
  • Nalin DSouza
    Nalin DSouza Jun 24, 2009
    Step 5: Note which cartridges printed which areas of the diagnostic page
    Identify which cartridge printed which part of the diagnostic page, so
    that if you find defects on the page, you know which cartridge is the
    problem.
    However,
    you can install different combinations of ink cartridges in your
    printer, and different cartridge combinations print different
    diagnostic page patterns. The diagnostic page might not look exactly
    like the example presented here, but the right and left cartridges
    print in the same areas of the page no matter which cartridges are
    installed.
    Figure 3: Diagnostic page layout (the patterns in each area might look slightly different on your page)
    1 - Printed by the right cartridge
    2 - Printed by the left cartridge
    NOTE:
    If
    you are printing in reserve mode (one cartridge is missing), the area
    of the diagnostic page where that cartridge prints is blank.
    Step 6: Look for defects
    In
    general, if the printer and print cartridges are working properly, the
    patterns (which look like grids of lines) should contain few or no
    missing lines. Also, the colors of the patterns and bars should be
    approximately the same as the color dots on the print cartridge label.
    NOTE:
    Do
    not compare the colors on your diagnostic page to the colors on this
    Web page. Unless your monitor is calibrated, the colors will not be
    correct. Instead, compare the colors on the page to the colors dots on
    the print cartridge label. While the color dots may not be perfectly
    accurate, they are likely to be more accurate than the colors on the
    monitor.
    Missing lines or streaked bars
    If a pattern shows more than a few missing lines, or a bar is streaked, that print cartridge is not functioning properly.
    Figure
    4: The right cartridge (a photo cartridge) shows missing lines and a
    streaked bar - the cartridge is not functioning properly
    Figure
    5: The left cartridge (a tri-color cartridge) shows missing lines and a
    If your diagnostic page shows missing lines or streaked bars,
    click here to continue troubleshooting
    Color mix
    If
    the color of the patterns or bars is very different from the color dots
    on the cartridge label, the cartridge is not functioning properly.
  • Nalin DSouza
    Figure
    7: The color of one of the left cartridge bars is very different from
    the color on the cartridge label - the cartridge is not functioning
    properly
    If your diagnostic page shows colors that are very different from the colors on the cartridge label,
    Missing colors
    If any of the color blocks or patterns is entirely missing, the cartridge is not functioning properly.
    Figure 8: The yellow pattern and bar for the left (tri-color) cartridge is missing
    If any of the patterns or color blocks is entirely missing,
    Ink smears
    If the diagnostic page shows smeared ink, you may need to clean your cartridges.
    Figure 9: Left (black) cartridge shows smeared ink
    If your diagnostic page shows smeared ink,
All photos are printed with a blue tint behind them.
#Perform print head nozzle cleaning from printer properties..
# Do align print heads.. check.. repeat 2-3 times till good result comes.
Aug 02, 2015 | HP CR769A Officejet 7610 Wide Format All...
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
http://h10032.www1.hp.com/ctg/Manual/c01518966.pdf
Feb 18, 2014 | HP Photosmart A636 Compact Photo Printer
Red and blue tint
Often "grayscale" is achieved by mixing some of your colors (CYM) to form composite black and gray - not necessarily just black from your black cartridge. Often there is some yellow used beneath the black -- so if you are getting a red or blue tint, it could mean something as simple as being low on yellow ink.
Jan 26, 2014 | Office Equipment & Supplies
HP 1220 C--ran out of yellow. Put in new cartridge. In fact tried two sets of new color and black 78 and 45 cartridges. Test prints look fine. But when I print an 8x10 photo--have tried eight or...
Hi! The problem will surely be on the printer head. It may have reached it's break point that when it performs a larger print outs it fails on the half. You can replace the head itself but I strongly suggest that you purchase a new one for optimum performance. Hope this helps and thank you for using FixYa!
Nov 05, 2010 | HP DeskJet 1220c InkJet Printer
I have an Epson Stylus Photo 1800 printer. Though I have checked and cleaned the heads there is always a faded light line about a half inch wide on each 8x10 print. I am new to printing and did not...
Try running a clean/alignment on your printer. There should be a utility program bundled with the software that will perform this function. Chances are the line is there due to one of the print heads being out of alignment.
Aug 21, 2009 | Epson Stylus C86 InkJet Printer
Faint rainbow line of blue/orange/yellow at end of printed photo
You might try cleaning or unclogging the print head[s] with a drop of water or two onto the outlet from the print cartridge[s] and a drop of water or two onto the inlet orifice into which the outlet of the cartridge feeds the ink.
May 18, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Aligning Print Head Alignment
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model).
Press the right ARROW repeatedly until the display window reads Maintenance.
Press ENTER.
Press the right ARROW repeatedly until the display window reads Align Print Cartridges.
Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page
Verify that the alignment was successful after the page is complete.
Oct 04, 2008 | Canon BubbleJet i550 InkJet Printer
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Excessive Yellow ink use
The printer software should have an option for head cleaning & alignment. Make sure to run these maintenance options and see the results. You may need to re-run the tests.
Sometimes generic inks can cause a problem, so after cleaning, try to use an oem cartridge (same company as your printer) and observe the results.
Jan 24, 2008 | Office Equipment & Supplies
Yellow won't print with old or new cartridge
Some ink jets are differant. Some have an Ink jet cartridge system that has the print head on the cartridge itself. Others use a seperate print head. When you pull out the ink cartridge is there another small unit below the cartridge that you can pull out? If so that is the print head and you will need to replace it. Also make sure that you have taken off the tape off of the air pilot hole on the ink cartridge so it can work properly. www.tonerovernight.com
Mar 16, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
389 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
