Question about Raypak Pool & Spa
Raypak pool and spa heater won't tunr off - Raypak Pool & Spa
    Top Expert:
  • Raypak Master
  • 3,543 Answers
Bad temp sensor
Posted on Jun 07, 2016
  • 864 Answers
SOURCE: raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
Posted on May 30, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Our Raypak pool heater is 14 yrs old. This year
What you probably need, you may be able to install yourself and save some$$$. It's call a thermocouple. It's a long thin tube that has a probe bulb at one end and snakes it's way back to the gas regulator.14 years is plenty of service to get from one of these.Don't laugh, but often times you can find a good one on anold gas heater in the metal pile of your local dump. It's worth a peek. If not get one of your heat and cool contractor friends drunk, then ask him to pick one up at the gas company. Town laws vary greatly from town to town. Here in Provincetown we can hardly change a light bulb without a permit...lol. Good luck, I have faith in you. Thanks Dana.
Posted on Aug 21, 2009
  • 366 Answers
SOURCE: RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Posted on Sep 16, 2009
  • 2458 Answers
SOURCE: Pool Heater igniter wont light
Hi check out the power phile should be between 300 to 500 mille volts
Posted on Feb 17, 2010
adamh294
  • 310 Answers
SOURCE: Raypak pool heater - error code is "FAN"
In models older than 07-07 it typically indicates a loss of the pilot light.
In models newer than 07-07 it is probably the air switch not being activated, or it has just failed. Check air switch tubing for secure connections.
Posted on Oct 27, 2010
Raypak spa heater pr5 service code message
check pressure switch if no voltage both sides of switch bad switch or plugged copper line or loose wires
Oct 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RayPac Pool heater won't light
check gas pressure too low it overheated replace fusible link on bottom after gas is fixed then clean heat exchange of soot
Apr 20, 2012 | Raypak 130,000 BTU Natural Gas Pool...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool & Spa Logo
26 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
