Question about Mitsubishi LT-40151 40 in. HDTV LCD TV
Problem cannot get sound bar to work on sansui
How do l adjust my Sansui 4k ultra hdtv to get better sound?
You can't unless you buy a theatre Sound system. You can improve the picture quality but not the sound as you are tied to the tiny inferior speakers within the television. If you are stuck for space a sound bar and woofer speaker are a good alternative.
Apr 18, 2016 | Sansui Televison & Video
Yesterday my sansui was not showing any picture although it was on,the screen was cold. today the power button does not turn on.
Sansui HDLCD3700 -- Turns On, No Picture/Sound - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
May 20, 2013 - 7 posts - ‎3 authors
Sansui HDLCD3700 -- Turns On, No Picture/Sound ... My Country: USA ... not been able to get any sound or video at all (no backlight either).
Sansui hdlcd185w repair - YouTube
? 2:25
https://www.youtube.com/watch?v=qMpiC8YL3SE
May 31, 2013 - Uploaded by After Hours Tv & Pc repair
Thanks so much for posting, saved my kitchen tv from the landfill!... Also the buttons on the side of the tv do not work correctly. ...Any suggestions? .... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW - Duration: 5:29 ...
Jan 08, 2016 | Sansui Televison & Video
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
Sansui to DTV converter box
The model number you provided is for the Sansui tv remote. Are you trying to set up a universal remote that works with your new tv?
Nov 26, 2013 | Audiovox Code Alarm Pt-6c/goh-3bl98 Alarm...
Sansui Amplifier Remote
Logitech might haven't the set up codes to your Sansui Amp. http://electrohelponline.blogspot.com/ Check this link. Pull up older posts there. Check which model and make remote control have direct entry setup codes to Sansui Amps. The link have code list and set-up procedure to many devices to most popular remote controls. http://electronicshelponline.blogspot.com/ Check this link too. Pull up older posts by its left side bar or see them in Timeslide view.
Jun 16, 2013 | Televison & Video
How to remove the demo bar from the SANSUI 19
kindly off the CC option or close caption..
Aug 25, 2012 | Sansui 19 in. LCD TV
I have a picture but no sound on my sansui tv,can i get the sound back ?
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Some ads with posts too might help you.
May 29, 2012 | Sansui 32" TV
Need Sansui C-1000 Audio Amplifier Comcast 5-digit remote code.
Hello
Try these linkd to download the code list [5 digits] for Comcast. copy and paste the link into your browsers' address bar and press enter, if you do not get it as a link from here.
digitalnow.comcast.com/Contents/DTARemoteGuide.pdfSimilar
www.comcast.com/.../Digital.../Digital.../remotes/Remote_M1067BX...Similar
http://www.dataentryjobs.us/67948.html
www.ua.edu/.../aux.../trouble-shooting-and-remote-programming.pd...Similar
http://www.dslreports.com/forum/r20052833-Comcast-remote-setup-question
Feb 28, 2012 | Audio Players & Recorders
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
Jun 10, 2011 | Sansui HDLCD-1900 19 in. LCD Television
Sansui VCR/DVD
Cant' get remote buttons to work. No buttons work so can not watch DVD or Tape but can hear sound. Without the TV/VCR button not respondingnit won't switch over.
Jul 06, 2009 | Sansui VRDVD4005 DVD Player/VCR
Mitsubishi LT-40151 40 in. HDTV LCD TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
