Question about Samsung Washing Machines
Samsung 5 kg top load washing machine.
I had a brown out on Monday night and now my new samsung washer wont show soak and will not fill. I had checked the tap connected to it and its working fine. Is this a warranty problem because the retailer wont fix a blockage on warranty.
I cant afford a plumber as Im on disability payments, and the retailer also states on the receipt he expects me to bring it in. With a damaged spine this is impossible.
Any help would be appreciated. I also cant find the manual that came with it. its model number.SW50USP. thanks sara
  • 3 Answers
SOURCE: Frigidare front load washer warranty
The usual factory warrenty periord on the Frigidare Affinity washer is 1 Year from date of purchase. You can find your Model number and serial number of your washer on the inside of the door. It is on a white label towards the bottom of the dorr.
Posted on Nov 12, 2007
SOURCE: moffat washing machine older really older cant find model number
clothes need be more drye ofter end work
Posted on Feb 25, 2008
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
SOURCE: Steps to disassemble Maytag washer's transmission mod LAT9704AAE
I had an outside service tech. to repair it . He replaced seals and bearings .
Posted on Apr 02, 2009
I need the user manual for my Samsung 10kg top load washing machine. Model number WA455DRHDWR. I am having problems with it.
here's a list of parts, i don't think they sell manuals for washers.
http://www.ereplacementparts.com/samsung-wa456drhdwraa0001-washer-parts-c-505667_505689_506464.html
Jul 08, 2017 | Samsung Washing Machines
What is the max load for an indesit 1234T washing machine please x
  • From the manual
    Maximum dry laundry
    load
    heavy fabrics
    maximum 5 kg
    delicate fabrics
    maximum 2 kg
    pure new wool
    maximum 1 kg
    mixed loads
    maximum 2,5 kg
    How heavy is your
    laundry?
    1 sheet 400-500 g
    1 pillow case 150-200 g
    1 table cloth 400-500 g
    1 bathrobe 900-1200 g
    1 bathroom towel150-250 g
Sep 14, 2014 | Indesit W 123 Front Load Washer
Showing error E5
E5 is error code 5.
It means the water is not filling correctly (or the sensors are not noticing the fill correctly). Make sure the water supply is on and hoses are not kinked. If all water supply is ok, then the valve(s) may be bad. They are expensive so best checked and replaced by a technician.
Jul 29, 2014 | Bosch WAB28060GB Maxx White 600 mm Washer...
I want to keep the water in my Roper top load washer overnight so it will soak the load of whites I have started but the machine drains.
You should be able to select a soak cycle without having to turn off the water supply, but it may time out eventually and drain the tub. This p[events oversoaking the clothes
Oct 13, 2012 | Roper RAS8445KQ Top Load Washer
My new washing machine wont fill and the soak light is out. we had a brown out two days ago
This may help, if your machine is electronic, try disconnecting the power cord for 5 minutes, if this doesn't do it, the brown out has caused a lt more problems.
Jun 23, 2009 | Washing Machines
Washer fill with water when it is not on...
remove top 3 screws in rear of top panel..left rear corner water valve where hoses come in replace it not shutting off completely
May 19, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
