Question about Husqvarna YTH2454 54in 25 HP Lawn Tractor
Blades wont engage
Was mowing fine shut off for 20 minutes now blades wont engage
2 Suggested Answers
  • 7 Answers
SOURCE: I have a Husqvarna EZ4824 that surges after a short time mowing. It runs great until you engage the blades and mow for a few minutes. I have replaced the air and fuel filter. I have had this mower thr
If the engine surges take a look at the governor spring. It sounds like the engine is reacting to load
Posted on Apr 18, 2013
Craftsman Model Number: 917.377151 motor shuts down when blades engaged
The engaging of the mowdeck is cause an excessive demand of your engine. From that, we can assume your problem is in the deck. Since the power drive is all about belts and it threw the belts, from your information I can only deduce that either an object (stick-wood-rock) has wedge into a position that has stopped rotation of the blades. Also, each blade has a pulley/spindle. These have bearings which must be free to rotate.
A bearing failure or seizing can also cause the problem you report.
Follow safety rules in your manual to insure the engine cannot start. Attempt to rotate each blade to check for free rotation. If the do not you most likely will need to remove the mower deck and check further. An obstruction or seized spindle should be easy to determine and sit repair is easily possible.
Sep 03, 2016 | Craftsman Garden
John deere shuts off when mowing
sounds like you have sensor gone wrong.try to check what sensor you use thru your manual
Jul 17, 2014 | John Deere 1966 110 Lawn Tractor 7 Sprayer...
Blades wont engage
Check for power to the clutch from the switch or could be a bad relay
Jun 16, 2013 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Dies when try to engage blade
there is a switch underneath seat that shuts blades off if not pushed down or there is another one on the reverse that shuts off blades off when mowing one could have went bad hope it helps
Apr 16, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Engage blades engine shuts down
if you removed the seat and then placed a fuse in the plug for the saftey switch and then started having this issue . with my experience with the safty switches on the seats most are open as not connected to make a circut when your sitting on the seat or pressure is applied to the seat . try removing the fuse and attempting to start mowing or least ingauge the blades and that should fix your issue ... when removing the origonal seat you just left that curcut open so it can not close and make connection when you get off the seat . so you should be fine after removing the fuse from the socket .. happy mowing
Nov 07, 2011 | Craftsman Garden
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Husqvarna yth 1746 mower deck won't re-engage once shut off
the safty swich is getting hot & wont alow it to engage again untill cool
Jul 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna YTH2454 54in 25 HP Lawn Tractor Logo
29 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
