HOW DOW i FIND A REPACEMENT BATTERY COVER FOR A METAL DETECTOR
  • kakima May 20, 2014
    What make and model metal detector? Have you tried contacting the manufacturer?
2 Suggested Answers
SOURCE: blue hat metal detector doesn't work
We are having the exact same problem. Looks like we either got a dud or the thing is a piece of junk.
Posted on Jan 10, 2010
How dowe fit a new leasure battery onour camper van please how dowe remove thepassengerseat
dont believe the design would make you unbolt the chair and remove it
will be either by sliding the chair right back
look for releasing the metal clips catches at the floor pan
as the chair is moved right back
then maybe tilting
Jun 04, 2016 | Cars & Trucks
IS THER A VIDEO THAT SHOWS ME HOW TO DO THE SETTINGS ON A MICRONTA 4003 VLF
It is one of the simplest ones to use. My niece used one for a while. I could not find a video but here are the instructions;
Instructions
    • 1Turn the metal detector on with the "Volume" knob. This also adjusts the level of sound.
    • 2 Check the batteries. Turn the "Test" knob to the Battery 1 or Battery 2 position and confirm that the needle points to the green area. Then turn the knob to "Nor" for normal operations
    • 3 Hit the red "Auto Tune" button on the carrying handle with the head portion of the detector away from any metal objects, and turn the "Tune" knob until the needle hits 0.
    • 4 Turn the "Sens" knob to the middle position.
    • 5 Turn the "Mode" knob to VLF (very low frequency), and turn the "GND" knob to account for the type of ground (such as dirt or sand) you are using the metal detector for.
    • 6 Turn the "Mode" knob to either the TR1 or TR2 position. To set the detector to find metals such as gold or silver, set the "Discrim" knob to Non-ferrous Metals. You can also set it to find Ferrous Metals if you want to search for iron or steel.
    • 7 Hold the detector with the search coil parallel to the ground. You can adjust the angle of the search coil by loosening the wing nut on the end of the shaft and swinging it to the desired position.
    • 8 Swing the detector in wide sweeps about 2 inches from the ground.
Read more : http://www.ehow.com/how_5011582_use-micronta-metal-detector.html
Jan 30, 2015 | Retail Supplies
I have replaced the batteries to the smoke detectors and they keep beeping. What is the problem?
It is possible that the battery is not contacting the metal clips inside. See if the can be adjusted out. More likely the detector is not recognizing the voltage of the new battery. You can try removing the detector from the ac power install the battery and reconnecting it to the ac. It should correct the issue.
Sep 16, 2014 | First Alert SA302 Dual System Smoke...
Were is the battery located in the GL722 model
4 3mm hex screws on the bottom of the laser will remove the lower cover (big metal grey bottom) and reveal 6 D cell's
Sep 16, 2013 | Trimble Spectra Precision Gl722 Dual Grade...
My tesoro metal detector isn't working
Test the Batteries if they are good, then you have a Wire or Circuit Board problem. This unit is very basic electronically
Apr 11, 2013 | TESORO Cortes Metal Detector W/ Multiple...
I need to know what batteries to put in my inductive voltage tester, Greenlee model 1010..
It takes two type 357 button cells. Fry's sells for $2, Radio Shack for about $3.
Make sure + sides goes into the body, not the cap.
Aug 12, 2010 | Greenlee GT-15 Non-Contact Low Voltage...
Non-working Live Wire, model 505-A
Operates from 2-LR44 1.5 Volt batteries .
The back cover slides off.
Jul 27, 2009 | Acer Gardner Bender GVD-505A LIVE-WIRE...
Turns on when I depress the on and off butto, but turns off as soon as I take my finger off of the on/off button
Bounty Hunter Time Ranger Metal Detector - Hello therre: here is a good place to start ok please dont forget to rate this solution it helps me out like we help you all out ok best regards mike Kellyco Metal Detectors Bounty Hunter Time Ranger Metal Detectors now has 2 packages available including ... Bounty Hunter Time Ranger Metal Detector with 8" & 4" Searchcoil. Option 1: ...www.kellycodetectors.com/bountyhunter/timerangerbuy.htm - 92k - Cached
Nov 07, 2008 | Bounty Hunter Digger Metal Detector
jasbo
jasbo
