How to reset toshiba tv DLP bulb - Televison & Video
3 Suggested Answers
SOURCE: Bulb or Lamp Unit Timer
"paison" was correct and his solution did work for me. Make sure you first select TV on your remote. Now hold down the dvd/vcr button at the bottom of your remote while also holding down the "volume down" button on th front of the TV. Hold until a "Blue Reset Menu" appears on the screen and say the timer has been reset. Noe just follow the on screen instructions.
Posted on Feb 05, 2009
dcramer531
  • 1654 Answers
SOURCE: My Toshiba backlit DLP 60inch
First thing I need you to try is to change the input cables around and see if you can pick up the signal that way. use an input that you haven't used before and while your at it. do a re boot on the sat reciever, I mean pull the card out and power it down, put the card in and power back up. This will take several minuts but it may just need to be re-set. Also if this does not help. Try re-booting the set, unplug overnight and let it set as long as you can, then plug it in and turn it on and see if it gets restored. This is uncommon so I don't wan't to make any guarantees yet. While your in the menu check and make sure your selecting the correct settings of for the devices, make sure some how things didn't get changed. If all else fails you may have a bad tuner board on the set, but like I said this is unusuall. Let me know tomorrow if any of these worked.
Posted on Mar 28, 2011
How to replace procector lamp in model 46h84 toshiba
Projection TV sets have three tubes - red - blue - green and they don't fail often...they are located inside the tv DLP TV sets use a single bulb and a clot wheel to make the three colors display...DLP bulbs do fail about every two years and will need o be replaced. Replacements can be found at www.TvRepairKits.com and its located behind a small door on the rear of the tv.
May 19, 2013 | Toshiba 46H84 46" Rear Projection...
First doesn't turn on, now it does but have NO immages, just sound
I would expect that the bulb has failed.
Toshiba DLP Replacement Lamp Toshiba DLP Bulb Part 1
If you decide to replace bulb I suggest that you replace with the best quality bulb. I found the brightness between good and best bulb was significant. I have ordered from the internet and have had great results.
There are other possible causes of lost video. The bulb is only the most likely.
Good Luck
Jan 29, 2013 | Toshiba 53HX71 53" Rear Projection...
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
May 04, 2012 | Televison & Video
The bulb blew and I replaced it. Now the colour is all messed up. There isn't enough red, and way too much yellow/green. I do not have the original remote for the TV. How do I reset the colour??
the problem is that you bought a Toshiba. i have a customer who we di the same thing with. spent hundreds on a bulb and toshiba had a little surprise for us. messed colors. Tried resets etc with no luck. i've been told that is is the nice expencive colour wheel or coloor board also costing a lot. The word on the street is that this is very common and people say that thier customer care doesn't care. I think that when the bulb blows it can sometimes spike the color wheel or color board vibrates the color wheel when it blows.Perhaps all of these angry customers could dynabolt their tvs to the toshiba staffs carpark, go the the higher people in the toshiba food chain
Jan 03, 2011 | Toshiba 56HMX195 52" HDTV DLP Projection...
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
When I trun on the tv there is vertical lines. If I unplug the tv it resets and is ok for a will. Now it blew the bulb again third time.
I think you have a issue with your light engine and you need to replace it to be honest with you this part runs from $250dls - $350dls check this link out
Toshiba got a lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Oct 26, 2010 | Toshiba 65HM167 65" Projection Television
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba 52" HM95 DLP green and red LED Blink>
If Fan behind Lamp is not running lamp will not come on,also CK blaster board.
Aug 09, 2009 | Toshiba 52HM95 52" HDTV Projection...
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
