Question about Akai LCT3201TD 32 in. LCD Television
How to connect high definition to LCT3201TD - Akai LCT3201TD 32 in. LCD Television
Can you hook up a digital converter to a akai model num lct3201td 32 inch tv
The converter box connects to the antenna input of your TV or, for better picture quality, L audio, R audio, and video outputs from the box can be connected to corresponding inputs on the rear of your TV.
Nov 02, 2016 | Akai LCT3201TD 32 in. LCD Television
Where do I put my power cord on my haier model40e3500
Haier 40D3500M LED TV Home Entertainment ' Haier US
www.haier.com/us/products/home.../led-tv/40d3500m.shtml
HaierSimple one cable connection for high definition audio and video. MHL enabled. Mobile High Definition Link allows you to connect compatible devices, such as ...
[PDF]OWNER'S MANUAL - Haier
image.haier.com/manual/tv/LEDTV/.../P020111018525755526455.pdf
+/- . In the MENUscreen, these buttons serve as up/down buttons. 5 POWER. Press to turn on and ... Connect cable pr antenna signal to the TV, either directly or ...
LE40D3281 LED TV - Haier
www.haier.com/us/products/home.../led-tv/le40d3281.shtml
Haier 48D3500 LED TV Home Entertainment ' Haier U
Dec 16, 2015 | Haier Heating & Cooling
What is Hdmi used for and how to use it
HDMI is a high definition video/audio cable. It is used on newer tv's and surround sound receivers. You need to make sure that your TV supports HDMI before you can use it.
Please remember to rate my solution to show your appreciation.
Amardeep
For more tips visit my blog at http://thegeektweet.wordpress.com
May 28, 2011 | Philips Televison & Video
What is HDMI
Its a vidio/audio input which looks like this. If you have an hdmi port on a laptop you can connect it to a TV and have the audio and video transfer to the TV.
Mar 16, 2011 | Computers & Internet
Lct3201td has no picture
Check the inverter stage the mosfet ccfl drivers may be faulty.
Jan 06, 2010 | Akai LCT3201TD 32 in. LCD Television
Akai 27 inch lcd wont turn on and makes high pitched nioise
definitely needs new fuse, try 250v, i did - , mines still wont turn on, but at least yours is still having sound
Nov 25, 2009 | Akai LCT3201TD 32 in. LCD Television
Audio Output Problem
Select DVD Input source, then press the Setup button on the remote (it's under the DVD control block near Subtitle). Go to the Speaker Setup Page and select LT/RT or Stereo. After I set it up it seems to work for other Input modes also. I have the 27" model.
Dec 04, 2007 | Akai LCT3201TD 32 in. LCD Television
Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Oct 14, 2007 | Samsung HP-R4272 42 in. Plasma HDTV
Setting up ant1 or ant2
Try pushing the source button on the remote until it goes to ANT 1 or ANT 2, then that part of the menu will not be grayed out. (Sidenote) If you take a pair of rabbit ears and attach them to the antenna input that says air, you can receive high definition local channels. Autoprogram the set at night, that is when most channels that send that signal, usually, show it at night. If it continues, reply to this post and I'll respond.
Aug 26, 2007 | Akai LCT3201TD 32 in. LCD Television
Akai LCT3201TD 32 in. LCD Television Logo
16 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
