Question about Garden
What is the spark plug gap setting for a poulan pro 25cc pole saw
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: I have a Poulan Pro pole saw model sm446e. For
Without seeing the saw and pole we cannot answer your question.
Posted on Sep 23, 2009
gh0st07
  • 114 Answers
SOURCE: What is the air gap between ignition coil and fly wheel on a poulan pro pp4218 avx?
For practical application you can just use a new business card or 3x5 recipe card. You don't want to use same card too many times though because thickens of card will change with use, and exposure to liquids. I don't remember right off hand the exact specs but I do know we have used this method for years.
Posted on Jan 08, 2017
Need to do a tune-up. what are the settings on the spark plug and on the magneto gap.
The plug gap is 0.020". Use a thin business card for the ignition module gaps--turn the flywheel so that the magnets are under the module poles, insert the card into the gaps, loosen the module screws, and allow the poles to contact the magnets. Tighten the screws, and turn the flywheel somewhat to release the card. Then turn the flywheel one full turn to make sure the gaps don't close further. With a fresh spark plug, the spark should be blue and snappy. Hope this helps!
Dec 09, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Poulan 2375le chain saw. just replaced primer bulb, gas lines and diaphram. also has new gas and spark plug. will fire up but wont stay cranked especially when I mash the throttle. please help..
Check the fuel filter, air cleaner and muffler for plugging. Be sure the fuel and oil mix is thoroughly shaken just before filling the tank each time to prevent oil starvation. Set the plug gap to 0.020" and test the spark for being blue and snappy. If weak looking, remove the left side engine cover to expose the flywheel and ignition module. Turn the flywheel so that the magnets are just under the module poles, insert a thin business card into the gaps, loosen the module screws to allow the poles to contact the magnets. Tighten the screws, turn the flywheel somewhat to remove the card, then turn the flywheel one full turn to make sure the gaps don't close up further. Replace the cover and retest spark--if ok, try for start. Hope this helps!
Nov 11, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw cranks but wont run,new plug, filter and fuel filter.less than two years old
Take the spark plug out (gapped 0.020") and test for spark--it should be blue and snappy. If ok, pour a little fuel mix into the plug hole and try for start--if pops several times, then you have fuel delivery problems. If none/weak spark, then remove the starter assembly and side cover over the flywheel. This will expose the ignition module--set the pole gap using a thin business card for a gauge. Turn the flywheel so that the magnets are under the module poles, insert the gauge, loosen the module screws and allow to contact the magnets. Recheck for spark--if still bad, replace the module. Back to the fuel delivery problems. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Hope some of this helps!
Sep 13, 2010 | Poulan Pro Chain Saw 46cc 20"
Proper spark plug gap for poulan chain saws
I believe the proper spark plug gap for poulan chainsaws is .025-inch. That goes for all units.
Aug 22, 2010 | Poulan Pro Chain Saw 46cc 20"
Will not start type III 2.0 C.I. 16 inch chain saw
Remove the spark plug and test for snappy, blue spark. If nothing, try a new plug. If still nothing, remove the left side cover to expose the flywheel and ignition module. Remove the wire from the module that goes to the ignition switch and retry for spark. I now ok, look for problems with the ignition switch or possibly, the wire is grounding out somewhere. If still no spark, replace the module itself. Use a thin business card for a pole gap gauge, rotate the magnets under the module, set the gauge in the gaps, loosen the mounting screws and allow the module to stick to the magnets. Re-tighten the screws, and rotate the flywheel to remove the card from the gap, then turn the flywheel one complete revolution while checking that the pole gap does not close up at any point. Recheck for spark. If now ok, place some fuel mix in the plug hole and pull through--it should pop several times and maybe even run. If you get only pops, then check the fuel system lines and the filter in the tank. Make sure that the air cleaner and muffler are not plugged. Hope this helps!
Jun 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan 295 model chainsaw/ won't start, no spark
Start first with a fresh spark plug set at 0.020" gap. Make sure ignition switch is on. If still nothing, remove the cover from the flywheel. Set the ignition module gap by using a thin business card between the module poles and the flywheel magnets. Loosen the mounting screws, let the module contact the magnets, and re-tighten the screws. Turn the flywheel to remove the card, then rotate the flywheel on full turn checking that the gap doesn't close-up any further. Check for spark again--if still nothing, remove the ignition switch wire from the ignition module. Check for spark--if spark now occurs, check the condition of the ignition switch or the connecting wire may be grounding out somewhere in between. If still nothing, replace the ignition module. Hope this helps!
Jun 10, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
