Question about Honda 2007 Pilot LX
2007 honda pilot trouble code P0420 light goes on and then after about 40 or 50 miles goes off and continues that way but drives great.
If this the catalytic converter would the check engine light continue to go on and off?
3 Suggested Answers
  • 12 Answers
SOURCE: Check Engine Light on 2000 Honda Odyssey
The problem with an aftermarket catalytic convertor is the quality of the material that is in them. Used factory Honda convertors can be sold for 75 dollars. A used aftermarket catalytic convertor will sell for 5 dollars. If u truely want to fix this problem, you need to save up for a new Honda convertor and buy it.
Tom
Posted on Oct 24, 2009
  • 67 Answers
SOURCE: 2001 Honda - New Catalytics & O2 sensors -- new 0420/1739/1456
I would send the car for a smoke test for the emissions leak...Find out where the leak is comming from..Repair it..Reset the codes, then do a drive cycle and see what happens...
Posted on Feb 19, 2010
After driving my 2007 honda pilot for about 25 to 30 miles the engine light comes on then VSA light comes on then I lose power.SO I shut it off the car & have to wait a while then I can drive a li
Why did you not leave the vehicle at a repair shop or dealer
to be properly diagnosed & repaired
Any time you get any dash light on after the motor is running I
check for codes that day & get on with the required checking
& resolving within days or use another vehicle
You should stop using a vehicle with check lights & faults
& forget the free codes checks at the parts stores
Always use a professional scan tool & look at all data real time
generic & enhanced something a code read won't do & go for
a long road test with the scan along
Cylinder misfires will ruin an expensive exhaust converter
as will vacuum leaks,leaking injectors etc.
Today's vehicles need to be 100% or parked or you create
problems,do damage,run up your repair costs & shorten the
life of the vehicle all thanks to the Govt Emission non-sense
Mar 10, 2014 | 2007 Honda Pilot
Trouble code P0420, what it means? It is intermittent signal. the light "check engine
It's an O2 sensor telling you there is a catalyst problem. It could be the sensor or the converter itself. Have you been using cheap gas? Cheap fuel will do the same effect.
Apr 02, 2011 | 2008 Honda Pilot
2005 Honda Pilot, flashing Drive light on gear shift, 120k miles
This is a flag to let you know the onboard diagnostics have sensed a problem.No way to know what the problem is till you have the trouble code(s) retrieved from the computer by a professional with a scanner.The parts store scanners will not be able to access transmission computer trouble codes.Good Luck!
Mar 09, 2011 | 2005 Honda Pilot
I'm having trouble with a continuing trouble code being set the code is P0420, I've replaced both 02 sensors and checked all other systems all seam to be ok then at about 600 miles the light comes back on,...
p0420 is a converter code how many miles on vehicle has it been or is it running bad,exhaust leaks,damage to converter itself ?? any other codes in pcm
Dec 24, 2010 | 2000 Oldsmobile Silhouette
Mhy wife jus drove 200 miles and the the maintance light came on We're 300 miles away from my next oil change in my 2007 honda pilot. Could she get home without a problem?
Sure she can drive it. That light is only a reminder for you to service the vehicle, not a warning. Red lights are warning lights that need immediate attention. Yellow lights are reminders.
Nov 13, 2010 | 2007 Honda Pilot
Blinking green drive light
There is some problem with your transmission, get an engine analyser then you can see the error code i.e. telling the problem faced.
Apr 06, 2010 | 2005 Honda Pilot
Jun 29, 2009 | 2001 Honda Odyssey
Trouble shooting P0420 code, bank 1, OBD II for 2000'?
misfiring can cause a P0420 code.
I would recommend a set of honda plug wires and plugs if the P0420 code returns.
I have used bolt in aftermarket bolt in catalytic converters but don't remember the brand name they fit ok and i have had 1 or 2 return with a P0420 code out of about 20. I have never replaced the oxygen sensor on a civic like yours.
I always fix the misfire problems, reset the computer, and have the customer drive it and see if the code p0420 returns. 50% don't have the P420 code return. drive it and see what happens and go from there.
Jan 06, 2009 | 2000 Honda Civic
Honda 2007 Pilot LX Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
