Question about De'Longhi Heating & Cooling
Samsung ocs lcoven cooker lcd problem
The display not turn on
I HAVE A PIONEER MODEL XV-DV151 AND HAS OC ERROR
while stad by bottan pressing oc error coming on display
Jan 19, 2013 | Pioneer Televison & Video
I have A Compaq monitor,edited
omg an antique monitor
a relic CRT monitor?????really?
is it really MV320????or a typo.
MV500s are CRT (heavy cathode RAY TUBES)
you model is rare now, no photos of it by you.so...
if not a CRT pig.
then it must be a flat screen monitor
the first ones, up to year 2010 used crapppy
CCFL back lamp tubes that are bad now. all are.
(unless never used)
call CCFL fail these ways.
dim.
white now yellow
dead.
blinks, or is intermittent,or strobes.l
the backlamps CCLF tubes are dead. all do that, or just die .
crt monitors
are junk and a fire hazard, trash it.
CRT fails more ways
sure dim,sure dead.
but it has 3 guns , RGB , red green blue.
the red gun loves to go weak first , red phosphors
are weak (a physics deal)
one trick (long long ago is to up the red gun levels, to compensate.
or lower Green/blue guns.
gun means "electron gun" deep inside the CRT neck
The CRT has even more bad effects, failed.
a huge endless list , if you want.we have it.
with photos
Jan 23, 2018 | Compaq MV 520 Monitor
My 46" samsung lcd tv display keeps turning off
When it turns off, try flashlight 2 in from screen and see if you still see picture, if so then it's your inverter board is bad, you can price at shopjimmy.com or discount-merchant.com
Dec 18, 2010 | Samsung LN-R460D 46 in. LCD Television
The view screen in the back oc camera has stopped working.It only works when reviewing photos taken. Can anything be done?
Think that you might have just accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 03, 2010 | Canon PowerShot SX100 IS Digital Camera
The temperature display on the rear view mirror shows OC
The temperature display on the rear view mirror my 2002 Trailblazer LT is either way incorrect - like obviously too high or too low - but mostly just shows "OC" all the time. Is this an expensive fix? Is this an easy fix that I could do myself? What do I need to replace and how
Jun 30, 2009 | 2002 Chevrolet TrailBlazer
Dsc-363 displays code " oc err 1 "
It's output power amplifier ic problem. change ur output ic
Mar 08, 2009 | Pioneer DV-363 DVD Player
1997 Town & Country outside temperature display shows OC.
check the sensor itself it may have become disconnected, have a broken wire to it or be a bad sensor its located behind the grille
Jan 03, 2009 | 1997 Chrysler Town & Country
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Heating & Cooling Logo
82 people viewed this question
Top De'Longhi Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a De'Longhi Heating and Cooling Expert? Answer questions, earn points and help others
