Back to:
Tags:
Saeco Easy Espresso Machine
Coffee just does not get very hot
posted by jowen242 on Nov 04, 2007
i am having a problem with the temperature. my machine only gets the coffee to 140F i checked the hot water wand temp and it reaches 190F I hate the fact i need to put my fresh brewed coffee in the microwave to heat it up to drink it. Can I hack the internal thermostat? I just descaled the machine to see if this will help. No go?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 11, 2008
Not Rated (0)
mirran
Rank:Guru Guru
Rating: 88%, 216 votes
Hi Jowen,
How often has you descale your machine?
I think the problem is your boiler, if you have calcium in the boiler then you not get hot water from it:-(
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on coffee just does not get very hot:
I don't want to Accept this solution
Can you Help with these Coffee and Espresso Makers problems?
have you opened the base of the unit and looked to see if...
How do you program a Black & Decker DCM 1350 coffee...
Hi guys am looking at buying an espresso maker for our...
Call Thermos Nissan direct at 1-800-831-9242.
My Saeco Easy espressio machine recently started grinding...
Loading problems.
Repair Service
Find Coffee and Esp. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
