Question about Dell 3400MP Multimedia Projector
Fd630u solid red power light
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
After about fifteen minuetsof playing it turns it self off it also feels warm to the touch
Solid green or solid orange light: Your power supply is working.
Flashing orange, solid red, or no light: Your power supply may need to be replaced. Try the following solutions:
  1. Try plugging your console's power supply into a different electrical outlet. Do not use a surge protector.
  2. If the power supply light is solid red or flashing orange, unplug the power supply and let it cool for 30 minutes. Then, plug the power supply back into the outlet.
There is no crack or damage done to it right?
Also try plugging it into the wall dirteclty no surge or power strip and let it lay flat
Nov 19, 2013 | Microsoft Cpa09-010a Ac Adapter Xbox360...
The power light is solid red with no light on the status. I took out the bulb and put it back in now I have a solid red on the power and a solid yellow on the status. There is also no sounds coming from...
steady red with yellow/orange status light indicates that the temperature is too high, so by the sounds of it your device has malfunctioned, you need to get a repair on this
see page 44 here
http://vis.mitsubishielectric.co.uk/files/library/files/hc3800_manual.pdf
different model but same error code
Mar 06, 2011 | Mitsubishi HC3000U Multimedia Projector
I need to know the pin outs on the wiring harness for brake light,running light and turn signals.
Orange/white = Switched 12 VDC (tail light)
Red/yellow = Stop light
Solid brown = Right turn signal power/signal
Solid purple = Left turn signnal power/signal
Solid black = Ground
Aug 08, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
Solid red power light
pls check the power supply this happens when the router's supply is faulty or the power outlet in WALL ,
otherwise try this see for RESET button on the back of Router press it for 30 SEC when ur router is ON and it will resolve for sure let me know if it doesnt solve i can help more
RATE ME WELL !
Regards
Zohail
May 17, 2009 | 2wire (1000-400108-001) Router
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in)...you may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
http://www.xbox360forum.com/forum/xbox-360-console/64180-what-do-three-solid-red-lights-mean.html
Jun 16, 2008 | Video Game Consoles & Games
Solid red light after flashing firmware
These are the 3 things listed as being wrong for the status light being solid red:
1. Media is out. Reload a new supply. Press feed button to
continue.
2. Power-up failure. Switch power OFF then back ON.
3. Printer ready to receive flash programming during
firmware download.
There's a programming manual available for download on Zebra's website: https://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
It might help.
Feb 15, 2008 | Zebra LP 2844 Thermal Printer
26 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
