Question about Pentair Minimax NT Heater
Heater has been running and heating, but getting E02 error and HI
After heater has been running, it shows E02 and HI codes. I have also heard a knocking sound. The water is warm but not to correct temp.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Sounds like a water flow issue check your bypass valves check for clogged filter or thermal regulator ,or manifold bypass
Posted on Dec 10, 2014
3 Suggested Answers
Muzzi_123
  • 749 Answers
SOURCE: Minimaxpower on but fails to start no error code just flashes off
hi, it seems like a component malfunction, Try a hard reset Just unplug the power cord for 30 minutes or more, then try again.
Posted on May 07, 2009
  • 246 Answers
SOURCE: E02 error and heater will not start. Service
high limit is open this is due several factors like slow water .pump on low speed or dirty filter, also hard water, or assembly valve not working properly so make sure the filter is clean check the water chemistry an last check the valve assembly. make sure plumbing is correct water in and out from the heater
Posted on Sep 19, 2009
What's error code e02 Whirlpool water heater product # 100028736
E02 Water temperature exceeded high limit Switch the two house circuit breakers dedicated for the water heater to OFF and then press the reset button located behind the control panel on the water heater. Flip the house circuit breakers to the ON position. If error returns, call a service technician for assistance.
Dec 24, 2016 | Whirlpool Washing Machines
Washer does not add enough hot water
He is right, we can thank the energy mandate for than. In all new washers they are only required to reach 69 degree. All detergent are now activated at 62 degree no matter what. Some washers do get hotter but not lg
Dec 06, 2012 | LG WT5070CW 4.7 Cu. Ft. Ultra Large...
My Eternal Hybrid natural-gas hot water heater, Model Number GU195 stopped working, and gives a E02 error code. When the heater automatically attempts to burn, the natural gas doesn't, until the...
I'm having a similar problem. My water heater is Eternal GU195S. It will heat up the water it's in the tank so I will get hot water for a few minutes. Then whenever the system tried to heat up on-demand, it will not heat up and gave E02 error. If I stopped drawing water, the E02 error will go away and the temp setting I had will come back on. What could be the problem? I currently took it out of service and set it up outside my work shop for testing. Thanks.
Sep 08, 2011 | Heating & Cooling
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
My Bristan Meridian Show start ok with hot water then after a few minutes the water runs cold. Even if you try and increase the temp it still remains cold. You can switch of the shower and start again...
It sounds like 1 of 2 things to me. I will start wit hot water heater. The first test for the water heater is to have someone run the hot water while you hold the hot and cold pipes and see if the water is coming out of the water heater cold when the shower goes cold. Of the water heater is cold coming out then the problem is in the heater. ether a lower element is bad or the dip tube is broken at the top of the tank. if the hot water heater continues to put out hot water when the shower goes cold then it has to be the mixing valve for the hot and cold mix at the shower and that valve will have to be repaired or replaced. hope this gives you a good start. let me know if I can help further.
Dec 24, 2010 | Home
Washer will not fill up with hot water however it will with warm
Is your water temp on your water heater set high enough? If it is sounds like you are getting water from both hot & cold water valves. If temp is set correctly on machine temp switch may be bad on warm all time.
Mar 12, 2010 | Kenmore Washing Machines
Sep 05, 2009 | Pentair Minimax NT Heater
Heater will only heat spa water to luke warm.
sounds like it may be the thermostat on the heater. You are correct to check the filter first. if it is clean then it is probably the thermostat
Dec 19, 2008 | Jandy Laars Lt 250,000 Btu Heater
97 f 150 runs hot for minutes then runs ok
It could be a faulty thermostat. Did it do the same thing before u replaced the t-stat? It sounds like it's sticking closed, then all of a sudden it opens, coolant flows correctly. I'd consider changing it again. Check to make sure parts store is giving u the correct temperature thermostat also. Maybe it's too high for your Ford, delaying the opening.
Nov 25, 2008 | 1997 Ford F150 Regular Cab
Pentair Minimax NT Heater Logo
625 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
