Question about Epson Stylus RX500 All-In-One InkJet Printer
My name is sharon i have a problem
After replacing black ink i have now got lines in the print how do i stop this
  • Epson Master
  • 511 Answers
It's caused by waste ink around head spayer. Just print blank pages many times. It will clean itself.
Posted on Jun 24, 2009
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Apr 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer stopped printing colour
Are you using Name brand ,new ink cartridges?
Take the color cartridges out and make sure you removed the tape from the bottom of those cartridges. if done already take a wet paper towel and squeeze out the excess water, then lay the damp paper towel folded in half on a flat surface.
Then set the colored in cartridges one at a time with the ink side pressing against the damp paper towel for about 3 min. after 3 min you should see the ink drain on to the paper towel if so then replace the cartridge back into the printer and that should solve your problem.
Feb 14, 2009 | Canon i850 InkJet Photo Printer
Black Printer cartridge
It will tell you the colour is low, regardless of the format in which you are printing. I don't believe Canon provide a way for you to disable this for their printer range, so you'll need to put in the new colour cartridge to get rid of this error. (you should however, be able to print whilst receiving this message)
Jun 19, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
Maybe it will work for you! Good luck!
Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
Black ink
You could try flushing it with gen brother inks but more than likely you machine head is blocked and need replacement, very common and I'm sorry to say costly.
There is no easy fix for these heads on this machine, the only slight chance you have is to do a flush of the lines and head with good ink. To get to Maintenence mode you need to enter menu * 2 8 6 4 via keypad real quick, when you have done it correctly with speed, Maintence mode will display. enter in 76 arrow across to black then press 3 to select power purge then press the black start key.
This will use 1/3 of a ink and more times than not you will need to change head, but rather than that buy a new printer.
Brother inks contain additives that clean the lines and help stop blocking.
Nov 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
59 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
