Question about Panasonic Lumix DMC-FH5 / DMC-FS18 Digital Camera
System error focus , how do I reset factory settings, can't open menu to reset
Toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
Mar 14, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Hi a cannon eos400d camera multi focusing
is there any difference with flash in off position??
have you tried a external flash??
Sep 21, 2008 | Cameras
How fix the back focus of Nikon AF 70-300mm f/4.5-5.6G? unable to focus whatever adjust made from the lens.
Hello marion.... Rutn the camera on and open up the menu. Find the reset function and reset the camera. All that does is reset it to the factory settings, the settings it had when you first took it out of the box. In most instances this will fix the problem. If it does, great. If not, take it or send it into a Nikon repair shop. Opening it up your self will void the warranty. Joe
thanks for choosing Fixya!
Jan 12, 2011 | Nikon Zoom Telephoto AF Zoom Nikkor...
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
Dec 03, 2010 | HP LaserJet 4600dn Color Printer
How to reset samsung star to default factory
pls help me how to restore samsung mobile phone s5233w factory setting code
May 04, 2010 | Samsung Star GT-S5233 Cell Phone
I have the toshiba 42hl167 and the volume is not working. only works with play station. cant here cable or bose system.
I would reset the factory defaults on the TV, but some complicating information follows these instructions:
Reset Factory Defaults
To reset all settings and channels to their factory
default values:
1 Press Y and open the Setup menu.
2 Highlight Installation and press T. A new set of
Installation menu icons will appear.
3 Open the System Status menu, highlight System
Information, and press T.
4 Press C c to scroll through the menu bar to select
Factory Defaults.
5 Enter your PIN code (or 0000 if no PIN code has been set).
Because the PC and HDMI-1 inputs share the same set of analog audio inputs, the PC Audio menu setting influences the HDMI 1 Audio menu setting. If PC Audio is set to “No,” the HDMI 1 Audio setting changes to “Auto.” If PC Audio is set to “Yes,” the HDMI 1 Audio setting is set to “Digital” and is grayed out in the menu. (Also see item 5 on page 12 of manual and “Setting the HDMI™ Audio mode” on page 43 of manual).
There is also some good information on pp.20-22 and 54-57 of the manual - this one has a lot of audio hookups and settings.
-Tha Mp3 Doctor
Dec 17, 2008 | Toshiba 42HL167 42 in. LCD Television
Gphone Error
Maybe you can try to reset the phone back to factory settings (you'll lose all your data!!): 'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
Dec 01, 2008 | Google Android
Focus
Use the Setup menu to select English or Spanish as
the language for the menus and on-screen displays.
Adjust Color Balance Automatically or manually
(PerfectColor TM) using six colors, Magenta, Red, Yellow,
Green, Cyan and Blue. Reset the Color Balance to the
factory default settings. Align the focus (convergence)
of the TV's projected light beams or reset the focus to
the factory default settings.
Jul 01, 2008 | Mitsubishi WS-65515 65" TV
Nikons will not initiate shutter. Photo button error
i think your settings are at fault to reset to factory settings go throw your camra at settings and set all to deault the menu shuld cater for default as i rember
Jun 24, 2008 | Nikon Coolpix 5600 Digital Camera
Panasonic Lumix DMC-FH5 / DMC-FS18 Digital Camera Logo
19 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
