Question about Independent Kitchen Ranges
Part for INCL-30-SS
WHAT IS THE MOTOR PART NUMBER AND PRICE
What model is Marlin rifle serial number 201293?
TRY THIS LINK
http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
Oct 31, 2014 | Marlin MAR 70510 336SS 30-30 SS 61 20 WAL...
Charmglow Electric Fireplace motor JL002 wont turn
Answer: It is a 12v DC motor (the same voltage as a normal car) so you can fairly easily test it once you remove it (horribly painstaking process). It should be straightforward on the test method, but basically just put the positive (red) to the positive, and negative (black) to negative. If the motor does not turn, it's bad.
I am in the midst of this right now also, I pulled my $500+ electric fireplace apart (like 50 or more screws) and found out that the motor casing had melted a little bit, causing the motor inside to seize up that usually turns the artificial flame deal. I have searched everywhere to try to find the part for under $30, but I cannot. It is a very simple part, a 12v geared motor with about 15-20rpm. This motor should be about $10, but since it's a special item, it's $30 plus shipping... it took me about 30 minutes to take my stove apart to figure out what the issue was, then I have had the issue of having no part numbers on the product I was trying to find, leading me to attempt to describe it via google. This may be a product that I will send to china to replicate and sell here for the correct price. There is no need for the $35 price tag.
Jan 08, 2014 | Magic Chef Kitchen Ranges
Cooling fan failure on DEFSGG 36 SS.
We do not have this type of information. Contact Sears Direct for parts, they can get parts for most products like this.
Jan 16, 2012 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Where do I find a replacement motor?
May I get the make and model # to help you more.
Jul 28, 2010 | TecnoWind 75 cm (approx. 30 in.) Classic...
The blower fan is making a low squealing noise. is there a way to fix that
Yet it's bad motor, check see if the dealer will done it on a campain ( discounted price ) both ways you want the noise gone put in the new motor. even the new one might do it soon, I've seen some with the thid and 4th motors in em. customers are mad.
Jun 04, 2010 | 2007 Chevrolet Malibu SS Sedan New Cars
Hi, I have a Rival Stoneware Crock - Pot Slow Cooker, 37401BC SCV400 Series. It doesn't look like the SCV400-SS picture above. Anyway, the handle on the lid has broken, can I buy one? and how much would it...
Go to www.crockpot.com. This is the Rival site for slow cookers/crockpots.  Click on replacements and scroll down. Enter you model number in the space provided. The site will give you info on parts and prices. I think a new lid is $10.00. I don't recall seeing a price or part # for just a handle. Hope this helps and if you are successful getting your part, please give Fixya feedback on my solution. Thanks!
May 13, 2010 | Rival SCV400-SS Slow Cooker
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Aug 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Where is the access to my fuel pump?
the fuel pump in in the fuel tank and the ttank must be removed to replace the fuel pump module. here is a picture and price courtesy of rockauto.com
ACDELCO Part # EP381 {DOES NOT INCL STRAINER. #25163473, LIGHTDUTYTRUCK}
PUMP KIT,FUEL (ELEC) INCLS SEALS, BAFFLE & CLAMP $91.79, also replace filter or pump warranty will be voided.
Mar 16, 2009 | 1995 GMC Jimmy
1973 chevrolet nova ID number
there is no way to tell if its the original motor. but the vin. will tell you what size engine came with the vehicle.your local gm dealer can tell you which numbers and letters mean what. including whether or not it is actually an SS.
May 15, 2008 | 1985 Chevrolet Nova
Kitchen Ranges Logo
62 people viewed this question
Top Independent Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you an Independent Kitchen Range Expert? Answer questions, earn points and help others
