Question about Moen 82402 Adler Two Handle Standard Tub Shower Faucet Chrome
How to install a Moen Adler 82402 on non threaded copper pipe for tub spout
The kit has a converter to install on a non threaded pipe but, how long should the pipe stick out from the wall, how far should it go into the converter? It's very difficult to get the pipe to go into it and only fits in about 1/2 inch.
  • 20 Answers
SOURCE: Spout for Moen T991 doesn't fit valve 9993
The moen T991 fits a valve number 9997 or 9999
Posted on Apr 29, 2010
MNfisherman
  • 11896 Answers
SOURCE: Disconnect/reconnect drain part of MOEN
Should be 3 wing pipe nuts. One at basin base, and one on each end of you elbow. They should all turn counter-clockwise to remove. The one on the basin base likely and commonly has pipe thread tape on it.
Posted on Aug 08, 2010
Suzman
  • 642 Answers
SOURCE: Problem: Spout on Moen
The rotating spout is one of the features of the product as listed here. You can download the exploded parts view as well if you're not sure you got the assembly right.
Posted on Oct 17, 2010
packrat1948
  • 528 Answers
SOURCE: Installed a Moen Adler L82694
There is a restriction in the tube spout or the valve is in up-side-down
Posted on Mar 16, 2011
  • 190 Answers
SOURCE: how to install moen adler
Doug-
Moen makes six models of the Adler shower faucet. You can find the specific installation manual for the faucet you have on their website, at LINK. Select the unit you have and open the PDF of the manual on the following page.
Regards,
DIYpro
Posted on Jun 09, 2011
How to install moen adler thread end nozzle with adaptor
I have encountered different threads in different spouts, both old and new work. Yours may have a thread that is different from the adapter.
Feb 12, 2017 | Moen Plumbing
Moen 82402 tub faucet is leaking and I cannot remove plastic stem valve from copper pipe which has threads on outside for copper sleeve to go on
If you have removed wall tube and the retaining nut sleeve and any handle adapters, the cartage should just pull out. grip with vise grips and attempt to pull while wiggling and turning
Jan 22, 2017 | Moen Plumbing
I am trying to replace an old delta monitor 1300 diverter spout. It seems when I take off the spout it has a threaded part in the middle of copper pipe . The spout itself has a plasticinsert with threads....
Tub spouts are pretty much interchangeable although you may find the replacement spout cannot be installed easily because the threaded copper stub does not extend far enough to engage the threads inside the spout.
Nov 28, 2013 | Delta Faucet Delta T13422 13 Series...
When using the tub water comes out of the shower head
if the pipe feeding the tub spout is pex, cpvc or poly then it needs to be replaced with a pipe with a larger i.d. like copper or galvanized or reduce the pressure to the house.
Dec 01, 2010 | Moen Posi-Temp Single HandleTub And Shower...
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
How to install tub spout for delta model 174924 shower assembly
Normally, tub spouts are screwed onto 1/2" NPT galvanized pipe. I was unable to pull the spec for your particular tub filler, but I haven't found one yet that doesn't. I don't know why the builder didn't rough it in this way, but it will have to be fixed because there isn't any way to use anything but a threaded fixture (your other options are really only compression or soldered/sweated and you don't have the space behind the tub filler to do either of these). There should be a fitting in the wall (attached to a stud) that converts from the 1/2" copper pipe to 1/2" NPT galvanized. This piece needs to be added behind the wall so that you can attach your tub filler.
About the gap, it's generally a good idea to leave space around the pipe anyway so that minor temperature or humidity changes in the wall don't put stress on your plumbing and cause it to crack over time. That's one of the reasons why tub fillers are flared at the back (so that it covers the gap).
Sep 21, 2009 | Home
Tub spout. Moen
Hi handie Man,
I'm Harvey the Master Plumber.
Your problem is: Just bought a new tube spout to repalce my old one. The new spout same as the old, very common spout.. the inside of the spout has a (white) PVC threaded pipe in it with a smaller tube inside that as a O-ring in it.. You tried to unscrew annoying pipe but it wont budge.. and you dont want to ruin it incase you end up returning it. You think its just a reciver for a 1/2 inch copper pipe (which will fit).
That is exactly what it is. You've purchased a universal spout which requires a 1/2" copper pipe coming out of the wall. If you're not up to changing to that, take the old one to a plumbing supply. If you're lucky they might have a direct replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 15, 2008 | Home
Moen 82402 Adler Two Handle Standard Tub Shower Faucet Chrome Logo
54 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
