Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Ignites but wont stay lit - Jandy Lite 2 Natural Gas Pilot Light Heater
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I started getting the FL2 ignition failure error code on my Jandy Lite2 Spa heater again this week. I seem to get some variation of this problem every few years, by which point I've forgotten some of the details like which screws not to take out.
So, in hopes of saving someone else, and possibly myself, some
time in diagnosing this, here are some notes and pictures re
how I fixed it.
One time it was a bad ignitor. That's the part w/ 2 white wires sticking out just above the burners in the first shot. It's easy
to order online and replace.
The harder problem which I've seen most often is when the burner lights, but shuts off after about 5 seconds because the flame sensor doesn't detect the flame. The flame sensor is the glowing red rod to the right of the flames in the first picture. I took this shot after
cleaning it and getting the heater working again.
The second picture shows where it's mounted below the burner w/ one black wire leading to it. Don't remove the screw on the flame mount as the nut behind it comes off and is a bear to get back on. Besides, there's another screw that's nearly impossible to get to that keeps you from removing the sensor w/o removing the burner assembly.
However, I've found I can reach up from below w/ some steel wool and clean the corrosion off the flame sensor rod and that has fixed it
at least 3 times as I recall.
You should also check the burner tubes to see if they've been blocked by spiders. That happened to me once on a gas grill. Be sure to keep your face back when testing w/ the door off so you don't get singed.
Hope this helps!
- Bruce
ignites but wont stay lit - ignites-but-wont-stay-lit-zltpmto2tdzhf4nie1bxyhzb-5-0.gif
Posted on Dec 22, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
If pilot wont stay lit bad pilot generator
Posted on Nov 06, 2014
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
Laars pool heater's burner wont stay lit
Check the burner, the holes may be plugged, especially at the beginning of the season. Same happens to the pilot light tube. Spiders love to make nests inside those small holes clogging everything up.
Aug 13, 2014 | Teledyne Laars Pool & Spa
Oven wont stay lit
If you are talking about the little flame that is supposed to be burning at all times then you need to go to a hardware store and purchase a thermocouple. It is a small copper tube that sense's the flame. When working it will constantly burn a pilot flame so that when you turn on the oven it will ignite the gas in the burner. Once the burner is lit it will stay lit until the oven reaches the desired temperature. Replace the THERMOCOUPLE.
Sep 09, 2011 | Belling Solitaire G755 Gas Kitchen Range
Gas wont stay lit after ignition
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
Wont Stay Lit
I would suggest that you replace the thermo-couple. It is a long, slender copper "wire" that runs from the control unit to inside of the unit. THe thermo couple's job is to regulate the pilot light and the lit flame as well.
They generally cost about $10 and take 10 minutes to replace. Some of them are reversed threaded (rights loosen, lefty tighty) and some of them are regular threaded (righty tighty, lefty loosen). TUrn off the gas supply at the meter or an external valve and remove the thermo couple by unthreading it at the control unit. Bring that with you to the hardware store (lowes or Homedepot) to make finding the correct one a simple task.
I hope this helps.
Apr 24, 2009 | RTO Atwood Water Heater - 6 Gal LP
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
219 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
