Question about Panasonic PT-51HX41 51" Rear Projection Television
Tv turns off in 3 min with buzzing sound
I turn my panosonic tv on. i hear a buzzind soun and the tv only stays on for about 3 min. what can i do?
  • Panasonic Master
  • 5,138 Answers
CK next to FBT flyback transfomer your hori output transistor ther is a Blue capacitor 2K volts look to see if it is bad.
Posted on Jun 23, 2009
The tv made poping sound & it lost the picture but the sound was ok, their is buzzing sound coming from inside the tv, after about a min. the set turn off & red light stays on. reset tv, same...
This model is prone to a lot of problems to the point where a year or so ago they offered a chassis replacement on an exchange basis.
I would with rear cover removed try to localize first where the sound or buzz is coming from: The ballast? the Light engine? The power supply?
I can help but as I said this model has a LOT of chronic problems.
Steve
Nov 01, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 62 in 1080p turns on ,has sound but no picture
Your going to need to measure the various power supply voltages to see if its a bad main or power supply board
Nov 08, 2017 | Mitsubishi WS-65513 65" Rear Projection...
I have a GE 52 inch projection screen TV. I have replaced three CP's: 150, 114, 120. I also replaced the flyback. The TV worked only a couple of times. I turned it on, then off, and right back on. I only...
You can start with resolder deflection board around Hori output, coils and Big diodes also make sure 2 ribbon connectors are pushed in correctly and in good CK Both Ribbons .
Mar 24, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Set won't turn on. has a buzzing soune
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com for a refurbish power supply board.
Feb 20, 2010 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
No picture
I had a similar problem and got a TV repair man to fix it for real cheap. The whole fixing took less then 30 min and he goes to your house to fix the TV. He fixed it for an excellent price that left us astonished. He lives in NY. Email me if anyone needs his contact information. You wont be disappointed.
Mar 19, 2009 | Polaroid FLM-1911 19 in. LCD Television
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Jan 03, 2009 | Vizio L37 Television
Cloths were soaked !Won't restart, door locks and you hear a buzzind sound ??
Greetings JohnnyWrench,
Information provided by the manufacturer would indicate a few things possibly causing this:
1) Washer was overloaded, remove some of the clothes and continue the cycle.
2) Washer load was too small. Add 1 or 2 similiar items to help balance the load.
3) Load is out of balance, rearrange clothes to allow for more balanced spin.
4) Drain hose might be kinked, straighten drain hose.
You can also find a copy of your owners manual at
http://www.frigidaire.com/products/laundry/washers/front_load/prod_ATF7000FS.asp
I hope some of this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
Panasonic PT-51HX41 51" Rear Projection Television Logo
129 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
