Question about Vacuums
The power brush bottom is broken on my bissell 18Z6
2 Suggested Answers
  • 5 Answers
SOURCE: Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Posted on Dec 14, 2008
Bissell powerforce brush won't turn when powered
Hey, you may want to have check if the brush turns by hand without the belt in place. If the brush doesn't turn manually, you'll need to replace the brush.
Here's a quick link to the BISSELL website to assist you.
http://www.bissell.com/default.aspx?cid=ccsocial
Feb 12, 2013 | Vacuums
The turbobrush for my cleanview helix 22c1 is not working
It's probably either just dirty, or the belt is broken. If it's dirty, you can just take the cover off (two Phillips head screws on the bottom) and clean everything off the brush.
If the belt is broken, you can tell by turning the large gear at the back of the brush -- if the brush turns when you spin the gear, the belt isn't broken -- then you'll need to replace it. You can buy a new belt online, or you can buy a replacement Turbo Brush directly from Bissell ($24.99).
Hope that helps!
Jan 10, 2011 | Bissell CleanView Helix 22C1 Bagged...
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Need to replace a broken brush belt on Bissell Pro Heat Model # 88910-W
easy, unscrew the bottom plate, keep in mind that most bissell shampooers have one belt longer than the other based on the left vs right side
hope this helps
Sep 14, 2009 | Bissell 8910 ProHeat Clear View Upright...
Front revoving brushes dont revove
Remove the bottom of the power head(brush unit) and then you should be able to lift the driven side of the brush straight out. The belt is probably broken and this was caused by a build up of hair around the ends of the brush. If the belt is not broken just clear all debris from the brush area and look for a reset button on the brush drive motor. If it does not have one reassemble the unit and it should be good to go.
Sep 07, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes won't turn and vacuum will not pick up sprayed cleaner
There's a Capt. Obvious fix to check before you go any farther. Like many vacuum cleaners, the brushes on the Bissell carpet cleaners, by design, only spin when the handle is not locked in the upright position, so be sure to plug it in, turn it on, and depress the foot pedal to lower the handle while watching the brushes one more time to be sure that the fix isn't that easy.
If the brushes still won't spin with the handle in the unlocked position, lift the handle back up into the locked position, power off and unplug the Bissell, and look down and see if either of the two belts that make the brushes spin are broken, as a broken belt, or a belt that's come off the track, is the next most likely problem. Both belts must be unbroken and in the right place for the roller brushes to spin.
These belts can be seen in the clear plastic pieces on either end of the roller brushes. If you're having trouble locating them, **with the Bissell unplugged so the brushes won't suddenly start spinning and hurt your hand**, try spinning the brushes with your fingers while watching for the belts. They're black, about the thickness of two quarters, and the bigger one of the two (on the left end of the roller brushes, as you face the front of the Bissell), is just big enough to fit around both roller brushes. The smaller belt, goes around the back roller brush on the right and to a smaller cog wheel behind it. If you see a broken belt, or a belt off the track, that's your problem.
Here's a video you can watch for free on Bissell's website that tells how to replace a belt. I'm sure the belts can be ordered online somewhere or found at some Bissell dealers or repair shops. Note, again, the two belts are different. If only one is broken, be sure to order the correct one.
http://cache.vendaria.com/vpop/VpopV6.html?ct=13&ctname=CT630X556D630X390&fw=630&fh=556&logo=49&fv=10&ap=vnd_bissell_change_belt_proheat_2x&purl=MAIN_bissell_change_belt_proheat_2x&iid=sbpgzLIuvIlJlJquLvumgwqKqvIqvv&bg=ffffff&nm=BZOpener&curl=&err=0&title=Bissell&tp
If the belts are intact and in the right place, does the metal cog wheel behind the roller brush right turn when the Bissell is on and the handle is dropped? If not, then the motor that turns that cog wheel must be burned out.
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell liftoff brush wont turn
Check the connections on the bottom of the lift off part, and the matching connector on the bottom section. If bad, take it to a warranty repair shop for Bissell. Other wise it could be the brush motor that is bad, or the switch is bad.
May 15, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
Brush belt is very weak.
Brush Belt broken or disconnected. Very weak belt. Colossal engineering mistake by Bissell. Belt itself and its components are under way to much stress for the size they developed to perform their task. For Quality Control to let such an obvious blunder pass can only mean that it was intentional for reasons, Im sure, beneficial to Bissell and costly for the consumer. No telling how many people buy another entire machine when this rubberband of a belt breaks like it was intended. Bissell is not a consideration of myself or anyone I can enlighten.
Apr 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Vacuums Logo
15 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
