Question about Ryobi 10 Amp Electric Power Head RY15122
How do you fix a jammed trigger on the Ryobi 10 Amp Electric Power head
    Problem Solver:
Not really a fix but it worked for me. I opened up the case. Their is a little black box with a red button that must be depressed. Pulling up on the trigger pushes the button. Their is what i call a counter press above the trigger. By pressing it, it makes room for the trigger to slide up and press the red button. There isn't much you can do improve this process. But i took the two springs off the trigger and depressed them trying to shorten them thus reducing the force needed to press. The counter press in spring load. I carefully stretch it by pulling on the end directly above the trigger(not against the frame). This took some pressure off the counter press. I finally took a small file and carefully filed down the edge of the counter press where the trigger presses against. This makes it slide upward easier even if the counter press isn't pressed down fully when you squeeze it. The trick is pressing the counter press first, but doing these things has made my trigger a lot smoother. It use to be a hard press to activate, but now it is 10 times better than it use to be. Good Luck!!
Posted on Dec 16, 2014
  • Bernie Palmer
    Bernie Palmer Apr 28, 2016
    Thanks Roger - Just a few minutes with a file and all is good - the safeties function and the trigger is just like a Glock now....
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a Ryobi RE175. It just stopped working
1. Shut the power off, and disconnect your Ryobi
router. It could be the start/stop switch. So, you
can begin checking the switch contacts using the
multi-tester. Set if at 1 x 10 Ohms. Put the probes
of the tester across the switch terminals. Pressing
the trigger on will move the tester indicator to zero
if your switch is okey. Otherwise, no moverment -
the trigger switch need replacement.
2. Should the trigger switch proved to be okey, Check
the carbon brush of the unit, short carbon brush??
you have to replace it.
Nov 03, 2009 | Electrical Supplies
Ryobi Reeleasy line trimmer head PROBLEM
sounds like the clip isn't engaging properly. For a bump and feed they have steps that lock when enough cord is set out. If the head is not locked when its on it will recoil in. Try to make sure its not sitting wrong.
Apr 20, 2017 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Electrics trigger switch completely jammed
go to eurton electric. they have replacement switches.
Oct 13, 2009 | Drills
The trigger on my ryobi backpack is not functioning properly.
You need to buy a new cable, clarified by Ryobi Tech Support.
Jan 18, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi 10 Amp Electric Power Head RY15122 Logo
229 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
