Question about Husqvarna Garden
Yth2454 mower deck belt keeps coming off when I engage it to mow could this be the electric cluch?
Yth2454 mower belt keeps coming off. bearings and pullys are good. could it be the electric clutch?
  • 376 Answers
Simply.no
Posted on Jun 02, 2014
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
When running the mower, it shuts off immediately when trying to engage blades(pto)
Hi Digger:
I've two possibles come to mind for you to check.
1) Engine OFF - Make sure that all of the blades and pulleys can turn freely.
2) Engine OFF - Double check belt routing. Move engage lever ON/Off and look at what movement happens. It may be that the belt is on the wrong side af a mounting flange and binds when engaged.
Cheerfuls.
Sep 18, 2015 | Garden
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
Clutch adjustment for engaging dec
You clutch is probably OK. This sounds like some binding in the mowing deck.
  1. Take off the deck.
  2. Clean the underside of the mowing deck.
  3. Remove the belt and be sure all the moving parts move freely. If something is bound, try to free it up with oil.
  4. Replace any bound up bearings. Bearing are a very high maintenance item on a mowing deck.
Good luck.
Apr 05, 2015 | Garden
My deck mower(craftsman 917.271530)keeps shredding deck belts
You either have a bad bearing on one of the pulleys or one is loose and moving up and down drawing the belt when it is engaged. I would pull the mower deck off and go through it .
Apr 17, 2012 | Sears Garden
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
248 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
